Wiilnot drain water on spin cycle - Washing Machines
  • 15,935 Answers
ECU or lid switch failure.
Check and replace accordingly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
My washing machine got to the spin cycle but didn't drain water
prolly cuz you didnt check your pockets first and either change or a set of keys fell out
Aug 15, 2009 | Washing Machines
CANT DRAIN OR SPIN WATER OUT OF MY WASHER
you have a clogged water pump....its simple to unclog but thats whats wrong a clogged water pump
Jan 29, 2009 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
