Question about Garden
I am able to start the chainsaw. But when I give it gas the motor dies.
    Filmmaker:
    Uploaded 5 video answers.
  • 15 Answers
The problem is that your carburetor needs to be cleaned and possibly rebuild it most likely has a little tiny piece of dirt on a point in the carb, if this doesnt help then try tuning the carburetor if that doesnt work try the air filter and when all of this does not work put the saw in for service at your local small engine repair shop
Posted on Dec 01, 2012
I have the kit craftsman chainsaw 18 inch, with 42 ml engine. The problem is when you finally get it started, it dies when you give it gas. I need an answer please?
I see this problem a lot, so I just decided to research the problem. Yes, it is a known problem with chainsaws. Put down to fuel starvation for a number of reasons.
dirty/stale/contaminated gas
clogged fuel filter
clogged air filter
incorrect carb gas to air mixture
wood particles in carb jet
loose carb
http://www.bing.com/search?q=craftsman+chainsaw+dies+when+you+give+it+gas&qs=n&form=QBRE&pq=craftsman+chainsaw+dies+when+you+give+it+gas&sc=0-0&sp=-1&sk=&cvid=1987a3ed5bd649c2a6cb89f99f270d8b
Nov 10, 2015 | Craftsman Garden
Tip
Chainsaw erratic - starts - won't start - dies at steep angle
My chainsaw was erratic. Sometimes it started and ran just fine and at other times it just refused to start or died as I raised it to cut a limb. What I finally realized is that chainsaws are different than other 2 cycles engine devices - they have to work at many different angles (including straight up). For that reason, the fuel filter that is in the gas tank is weighted to keep it at the bottom of the gas tank as you raise and/or lower the chainsaw.
On my Mccullough, the gas line broke right at the weighted filter, allowing the gas line to flop around. That's why it was erratic and died when I raised it to cut a limb. So, if you have erratic operation, take a minute to check your gas filter and be sure it's still attached to the gas line......
on Jan 16, 2017 | Miscellaneous
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
Saw dies when giving it gas
It dies because it's flooding as you increase the amount of flow, a small carb adjustment is needed. As far as the leaking bar oil, if the saw has a pump replace the gaskets between the motor and the bar and reduce the amount that the saw puts out when running. Let me know if that cures the problem.
Sep 17, 2012 | Poulan Pro Chain Saw 46cc 20"
No spark for chain saw
Make sure the ignition switch is "on" position and ground the spark plug solidly, on a clean metal part to make a better electrical connection. Also, sand/clean the contact points of the plug to help the arcing. If you see arcing, then wet the tip of spark plug with gas and replace and give it some pulls, if it starts and dies, you will know that you have a "gas" problem....
Aug 28, 2012 | Homelite 150 Automatic Chainsaw Powerhead
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Stops running AFTER A COUPLE MINS
If it starts OK and runs fine for a few minutes you may have debris (dirt) in your gas tank. The dirt settles on the bottom, you start the motor and through vibration and shaking the dirt gets mixed up in the gas and sucked onto the fuel filter until the motor starves and dies. When the motor dies the dirt settles back on the bottom and you start all over. With the motor off, shake the gas up well and drain the tank into a bucket so you can check for debris. If there is a lot, half fill the tank, shake it up and drain again. Also, you may want to check your gas can to make sure the debirs isn't coming from there.
Sep 23, 2010 | Husqvarna Chain Saw 18" 450 Model...
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain doesn't move / clutch
Starts then.... you hit the trigger... ba ba ba .... dies ?
Check fuel filter in tank, make sure air cleaner is clean.
Make sur your mix is correct.
Feb 04, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My saw will start but dies immediatly
Spark plug gap The right spark plug and the right gap is critcal to good running on a 2 cycle motor(you DO have gas in it right?)
Aug 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
