Question about Ovens
The control buttons on my AEG Competence B6100 do not work properly any more.
Ie moving up between the various features is only possible one way, can increase temperature but not decrease. Now it's hard to switch on Do I need to replace the PCB and where can I get one? Ta, J
SOURCE: aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Posted on Apr 20, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence oven fan not working
If fan has stopped altogether, then you definately need a new one, to be sure you need to disconnect and remove the fan and bench test it.
Hook up a 240v supply to the fan and see if it runs, if not then it is no good..
It does not matter which terminals you connect live and neutral too as it is common to both terminals. do not connect feed to earth by mistake.
Plz leave feedback.
Posted on Dec 09, 2008
barkencoa
  • 3463 Answers
SOURCE: aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Thanks
Posted on Jan 27, 2009
barkencoa
  • 3463 Answers
SOURCE: AEG Competence Oven not working
If you are certain that the element is o/k, and it is not heating, then thwere are 2 possibilitues.
1- the oven thermostat could be faulty, whereby it is giving a feed to the element.
2-some ovens have a fan only setting, as well as heat and fan, make sure that it is not on a fan only setting.
Hope this helps.
Posted on Feb 05, 2010
barkencoa
  • 3463 Answers
SOURCE: AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 24, 2010
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
The top oven of our AEG D5701-4 is slow to heat.
Hi it could be the element on the grill it maybe burning out, what slows the grill to get hot quicker. best to turn of the mains or by the main switch. and get a toorch to check around the element or use a continental reader check if it is receving 240volts
Mar 09, 2010 | AEG D5701-4 Electric Double Oven
Hope this helps.
Feb 05, 2010 | AEG Ovens
Heat element is not coming on!
It is entirely possible that while cleaning the oven you may have inadvertantly bumped the element enough to cause it's connection to come loose enough not to work. With the power unplugged, wiggle the element where the connection is made inside the oven. If this does not work it is possible the element has 'gone bad'. Sometimes this happens from various causes and replacements are available from the manufacturer
Dec 04, 2009 | AEG Ovens
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Clock settings
press 1st and third buttons together. use rhs button to set time and it should then work
Jul 13, 2008 | AEG B1180-4 Electric Single Oven
AEG Oven
Probably there is an electrical relay that has failed.. or if electronically controlled, the equivalent circuitry. Or maybe a thermostat has failed. Be careful with anything electrical, as these kinds of faults may need a trained tradesperson. They can be dangerous to play with, as you need to be able to take electrical measurements and use tools to repair this yourself.
Apr 27, 2008 | Ovens
Ovens Logo
85 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
