Question about Activision Skylanders Giants Starter Pack Wii U
My wii console can't read my wii U skylander giants disc
I conect the portal to my wii console and the disc in the console the portal is on but the the disc can't read
    New Friend:
I can only pray this is a joke question. Wii ISN'T wii U. That's whyit wont work. It's like putting a wii disc into a ps3.
Posted on Feb 09, 2013
Portal on skylanders trap team says character has a problem, how can I get it to work
Unfortunately you have to replace the Skylander or the portal itself. If the portal will not recognize any other Skylanders then fortunately for you it is only the portal that needs to be replaced. If it will read the information from others then the character must be replaced, and more to the point... so will any work/gameplay you dumped into the toy. Like any other piece of computer data, the information maintained in a Skylander can become corrupted or wiped.
Mar 20, 2015 | HOW Video Game Consoles & Games
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
Will not read disc
The disc is probably scratched, if it is I would recommend buying the game again. If not then see if any oher discs are not working if others are messing up as well then it may be an issue with the wii.
Apr 19, 2014 | Activision Skylanders GIANTS Starter Kit...
My skylader from spyro's adventure has an error, what do I do?
If you are getting an error stating A toy on the Portal of Power has a problem, follow these steps to reset your broken toy.
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset. If you are resetting a swappable toy, you must reset both the Top and the Bottom separately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Your Skylanders toy will now work again.
If the screen turns black after returning to the game, try again starting with Step 1.
If the game won't load and you are only seeing an icon on the screen, remove the Skylanders toy from the Portal of Power, put it back on the portal, and try again starting with Step 1.
Jan 26, 2014 | Nintendo Skylanders Spyro’s Adventure...
My skylander on spyro's adventure has a problem, how do I fix it?
Try this :)
  3. Select Manage.
Skylanders Giants
  3. Open Settings.
  4. Select General.
PORTAL WILL NOT RECOGNIZE CHARACTER
  3. Select Manage.
  4. Select Reset.. If you are resetting a swappable toy, you must reset both the Top and the Bottomseparately.
Skylanders Giants
  3. Open Settings.
  4. Select General.
Sep 02, 2013 | Activision Skylanders: Giants Portal...
I have just brought the skylanders giants wii starter pack,when I start the game and it asks for me to put a figure on the portal nothing happens
Are batteries in the portal, is it synced with the console. To sync remove battery cover and SD card cover on the Wii press the two red buttons at the same time they are now wirelessly connected.
Aug 11, 2013 | Skylanders Wii Gaints Starter pack
Skylanders portal. my skylanders portal wont let me have more than one character on it at a time, how can i play two players?
Yes that is true, a portal of power cannot have 2+ skylanders on it. However, you may be able to use that same technique, but either use two portals, or put your skylanders down one after the other, not all at once.
Jul 29, 2013 | Video Game Consoles & Games
Trying to get started with the skylander giants game on wii, console will not read disc, any other game works fine, not sure what to do now
Check that it is the correct region format Eg: PAL or NTSC depending on country, If after you have checked this and it is correct then it could be a simple case of faulty media. To check if it is faulty media check the disk in anotherr Wii console if possible. If all else fails contact the store at which you bought it or the software company that has distributed or made the game. I hope this helps.
Jan 12, 2013 | Video Game Consoles & Games
Portal of power not recognizing Skylander so unable to play game
I had this happen. I tried a wired & wireless portal with the same issue. I reset the game a few times to get it going. I don't think it is a portal issue but rather an issue with the (Wii) game itself.
Apr 08, 2012 | Activision Video Game Consoles & Games
Activision Skylanders Giants Starter Pack Wii U Logo
1,137 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
