Question about Measuring Tools & Sensors
Fluke 1652 tester blown fuse - Measuring Tools & Sensors
    Master:
  • 683 Answers
Replace fuse with same rating. Not sure what the question is.
Posted on Nov 30, 2014
2 Suggested Answers
  • 4234 Answers
SOURCE: Fluke 1651portable multifunction tester is displays Err 1
Error 1 is an indication that the self test has failed. This will require repair at an authorized Fluke service center. There is an internal problem with the meter. The only thing that you can try is to replace the internal battery. Should the battery be defective, the internal testing can be effected. I have only seen this occur once, but it is worth the attempt. Should a new battery not fix the problem, return the meter to Fluke for repair.
Dan
Posted on Apr 15, 2010
Fluke 179 not working on voltage
possible blown fusible resistor (check for open or very high resistance - should be about 1kOhm) - first big resistor in Voltgae terminal circuit
Mar 16, 2013 | Fluke Networks Fluke 179 Electricians...
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
Fluke 705 loop calibrator fuse blown
Hello Bruno:
F1 (Fluke PN:800901 Ver. A,B and C) (PN: 1778294 Ver. D & E) is 350mA 600V fuse.
U11 (Fluke PN:687555) is DPDT Latching 5 Volt Coil
I would also check D12 if your revision has one (PN:1617521) which is sidactor and it's other side of the board (DO-214 58V).
Good luck.
Oct 26, 2012 | Fluke 705 Process Calibrator,current And...
MY FLUKE T5-600 WILL NOT TURN ON . I TRIED NEW
try checking connection of battery terminals to main board (you may need to bend them a little to make sure they touch main board once closed).
May 15, 2010 | Fluke Networks Fluke T5 600 Elec. Tester...
Dan
Apr 15, 2010 | Fluke Networks Fluke T+PRO Electrical...
Channel b on my fluke 97 50mhz scope is not working
if channel is blown then there is nothing that you can do - no parts are avaialable for repair of this model
May 20, 2009 | Fluke Networks Fluke T+PRO Electrical...
Measuring Tools & Sensors Logo
114 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
