Question about Refrigerators
Where is the reset button on the whirlpool model#ED5PVEXWS00
MY REFRIGERATOR IS NOT GETTING COLD
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
There is no reset button and you will need to replace the start relay. Here is the part to order. Below is a video to show you how to replace the relay. The model shown may be different but the process is the same.
Posted on Dec 01, 2012
5 Suggested Answers
  • 409 Answers
SOURCE: Side by Side Refrigerator not getting cold
hi there,
is it just the fridge or the freezer as well?
Posted on Sep 16, 2008
  • 415 Answers
SOURCE: My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Posted on Aug 22, 2009
dmftrucker
  • 1922 Answers
SOURCE: Refrigrator will not get cold
replace the control board in rear of unit $80.25
Posted on Nov 04, 2009
  • 1218 Answers
SOURCE: freezer works but the refrigerator side is not
Good day,
Two possible problems.
1. The fan motor located behind the freezer back panel is not running.
If you open the door, while the machine is running, you should hear it.
If not, remove the rear panel. If the motor is not being blocked,
replace. It's a little awkward, since it is clipped in place, but with a little patience, can be done.
2. The defrost system has failed. If when inspecting the rear panel, you see frost building up on it, that is your problem.
There are three parts to the defrost system
One. The main heater, which is located behind the rear freezer panel, and runs underneath the evaporator coil, and part way up the sides.
Two. The defrost thermostat, which is located on the top of the evaporator, and is a small round disk clipped to the evaporator coil, and has two wires leading from it to a plug.
Three. The timer, which is located in the fresh food compartment, under the roof near the front of the compartment.
To repair, unplug the machine, remove the rear panel in the freezer. Unplug the wires to the heater and check the heater for continuity. It should read very low resistance. Below 35 ohms. If it reads infinity, replace.
If the heater checks O.K. on this model, I recommend replacing both the limit thermostat and the timer, since both have a high failure rate, and the cost is within reason.
Parts may be purchased at any appliance parts house that carries Whirlpool parts.
Below is an excellent pictorial view of defrost system components. Unfortunately, the hyperlink to it may not work, and you will have to copy and paste it into your browsers address bar.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Dec 10, 2009
My Whirlpool Refrigerator ED5PVEXWS Not Getting Cold. We got up this morning and everything in the freezer melted. We bought it in November. it still gets power the lights are on inside. still under...
First thing I would consider is the=> W10135899 Defrost Control Board The first thing that stops is the compressor and fans most times when they go bad. You can find this board here=> ED5PVEXWS00 Control Panel Your control panel is found above the top shelf inside the fresh food compartment. Just unplug the power to refrigerator and lower the panel and where part 6 is in the photo is where the board is located. Most times when these boards burn out it creates this problem you described. Replacing that board should get you going and back to cooling normally. I will be here if you have other questions, Thanks, Sea Breeze
Apr 23, 2011 | Refrigerators
It freezes everything in both sides then warms up to 50 both sides it will get cold again it i push the filter reset button stay cold for a day or so then get warm again
IF YOU REFRIGE HAS DIGITAL COMPONENTS AND DIGITAL CONTROLS ,MAYBE ,,THE BAD COMPONENTS CAN BE MAIN CONTROL BOARD OR BAD TEMPETURE SENSORS..IF YOU REFRIGE IS UNDER WARRANTY CONTACT WHIRLPOOL TECHNICAL FACTORY SERVICES..
Feb 15, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Whirlpool fridge not keeping cold, but freezer is working fine. model et4wskxkoo1
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | Whirlpool Refrigerators
How do you reset the water filter light on Model # ED5LHAXWQ00, Serial # HR02227866?
Hi, I found this handy guide:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Rich
Refrigerator Repair Meridian
Western Appliance Repair
Oct 02, 2010 | Whirlpool Refrigerators
Whirlpool model gb22dkxgw00 bottom freezer working ok but refrigerator is warm i think the fan is not working but how do you get to it?
you may not be able to get the fan to go . if it is burned out . make sure the fan will turn easy and you can try a jumper cord to run it and if it runs look for thermo that has not reset when cold . ( called the defrost terminator .) poor connections would also caus this .. mm hope some of this will help .
Aug 18, 2010 | Whirlpool GB9SHKXL Bottom Freezer...
Oct 18, 2009 | Whirlpool Refrigerators
Aug 22, 2009 | Whirlpool Refrigerators
hi there,
Sep 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
