Question about Konica Minolta Minolta EP 2050 CS PRO Laser Printer Toner Cartridges
Call your technicl rep cod m2 - Konica Minolta Minolta EP 2050 CS PRO Laser Printer Toner Cartridges
Maintennce M2
M2 means time to replace the Drum, Developer, Cleaning blade, Cleaning pad & Drum charge corona assy. ( consumables). After you replaced it go to Tech. rep mode. to reset the counter & do ATDC Adjustment ( it will stop after 2 mins.) . Turn off / On and good to go ;-)
Nov 08, 2014 | Konica Minolta Office Equipment & Supplies
Mintenance call m2
M2 means Time to replace your consumables (drum,developer,cleaning blade,drum charge assy & cleaning pad) after replacement reset it to Tech rep mode.
Oct 28, 2014 | Konica Minolta Office Equipment & Supplies
How to clear err m2 konicaminolta
You can clear it @ TECH. REP MODE --> Maintenance counter, but i advice you to replace 1st the consumables M2 means your consumables (Drum, Developer, Cleaning blade, Cleaning pad & Drum charge corona) already reach its life.
Oct 17, 2014 | Konica Minolta bizhub Office Equipment &...
Reset error m2
M2 -waste toner box need to empty.
Displayed to indicated that the Toner collect count of the consumables counter has reached the set count.To reset select Count in the Tech.Rep.mode and acces the Consumables screen.Select the count of toner collect and press the clear key to clear the count.Place the copier in the Tech.Rep.mode by pressing the following keys:Stop-0-Stop-1.
Dec 30, 2013 | Minolta EP4000/5000 CS/PRO Copier
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
Preventive maintenance time code:M2
just enterto tech rep mode stop 0 stop 1 then select funtion then find maintenance counter then reset the maintenance counter
Nov 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Waste toner reset procedure for Di450
Here is the procedure. Please follow it carefully and do not go into any other areas. If you are not trained on this machine, damage could result.
1. Press the Utility key.
2. Press the Meter Count key.
3. Press the following keys in this order:
Stop then 0 then 0 then Stop then 0 then 1 or in other words Stop,0,0,stop,0,1
4. Select “Counter.”
5. Select “Consumables.”
6. Select the count of Waste Toner.
7. Press the Clear key.
Then you can turn the machine off then on again and the M2 Waste Toner should be gone.
Good Luck
Nov 24, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Mar 29, 2009 | Minolta EP4000/5000 CS/PRO Copier
Di520 black and white copier toner collection box
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Dec 30, 2008 | Konica Minolta DiALTA Di200 Copier
Diag code information
go here:
http://memweb.newsguy.com/~gtfour/technicl.htm#Fault%20Codes
Oct 16, 2008 | 1991 Toyota Pickup
Konica Minolta Minolta EP 2050 CS PRO Laser Printer Toner Cartridges Logo
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
