Question about Intertherm Heating & Cooling
How to relight pilot on intertherm model 411130
I had to turn furnance off because the thermostat is broken. Now that its earlymorning I would like some heat, but dont know how to light the pilot light on this thing. It looks nothing like a gas water heater
SOURCE: Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Posted on Aug 03, 2008
SOURCE: Vulcan qasar gas wall heater.
If your hearter is an electronic model the solenoid has almost certainly failed.
Posted on Aug 18, 2008
  • 659 Answers
SOURCE: Manually turn on base heater, thermostat broken
you can jump your w terminal over to the r terminal for manual but remember that the unit will not cut off on it's own.
Posted on Jan 05, 2009
  • 659 Answers
SOURCE: i have a intertherm model feh-017h electric
It's the heat kit in the unit that is causing the problem. You need to do a continuity test on it to eleminate that they have shorted. This is the only thing in an electric furnace that will blow a fuse on it. Intertherm is a Nordyne product for manufactured homes. Of coarse they still sell them! I am a Nordyne dealer. Also a sequencer can not cause a fuse to blow. The service guy just wants to make money from you by installing a new unit. You can either re-wire the heat kit or you can purchase a new one and have it installed. If you are referring to the heat kit for 159.00, then that's a fair price for it if you are a non licensed person.
Posted on Mar 17, 2009
  • 659 Answers
SOURCE: Clicking noise at the gas valve/pilot light unit
It sounds like you might have a spark igniter on the unit that is being told to relight the burners. This is probably the tstat as this is the only control that "tells" the unit to come on. There isn't anything else internally that will cause this problem. Replace your tstat and I bet this solves your problem.
Posted on Apr 05, 2009
I HAVE AN INTERTHERM MODEL MG-055AB TURNS ON BUT TURNS OF IN A 4OR 5 SECONDS ANY SUGGESTIONS
light pilot then turn blower on by thermostat. if it blows it out bad heat exchanger. if it stays lit shut down & pull burner assembly clean pilot orifice.
Feb 16, 2015 | Intertherm Heating & Cooling
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
I have a Charmglow ventless fireplace. When I light the pilot the furnance will run properly until it reaches temp. then it shuts off the pilot goes out and requires relighting if it relights. I took your...
In any gas heating appliance there will be a thermocouple that sense if the pilot flame is lit (lighted?).
You bypass this with the regulator by holding the button temporarily and that allows you to light the main burner. If the thermocouple is bad (not uncommon- they sit in a hot seat all the time), it will disable the gas supply.
The thermocouple should normally measure nearly zero Ohms on a multimeter; if it doesn't, it's bad.
If the thermocouple checks out OK, then the regulator has failed.
Oct 24, 2009 | Terminator Aquastar 125FX Tankless Water...
Heater won't relight or turn back on after the thermostat turns
Verify that your pilot is staying on if you have a pilot.
Some may have electronic ignition.
Oct 01, 2009 | Williams 1403622 Gas Compact Heater
Indoor fan motor continue to run even if the thermostat is in auto position with the cool and heat switch in the off position. The furnance don't have a fan on and off switch in the furnance like most....
Try this, disconnect the fanwire (green) on the furnace, if it shuts off then the hot wire from the thermostat is touching the green wire or bad thermostat. Thank-you-very-much!
Aug 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
52 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
