Question about Saniflo & Saniplus& Macerator Pump
Saniflow macerater wont stop running
When i flush my toilet some times the macerater stops normaly but the next time it will run on and on it seems to be every other time
  • 41 Answers
Sounds like a stick float vave check this link on maintenance of your system.
Check the masserator is clear also check the outflow pipe , maybe a good clean see this link for more info
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will may help.
Posted on Feb 07, 2013
  • 297 Answers
SOURCE: Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Posted on Jul 15, 2009
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Posted on Jan 24, 2010
  • 37 Answers
SOURCE: saniflo toilet top2
Sounds like you have blockage in the discharge pipe
Posted on Feb 26, 2010
garypetterss
  • 15 Answers
SOURCE: Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Posted on Apr 11, 2010
  • 1015 Answers
SOURCE: why does my macerater give off a smell some
You are probable getting a odor for a short time as sometimes when toilet is flushed it will break the water/gas seal for a second or two. One of the best things I have found to use with sewage and grease trap systems is called Wham. You may have to go to plumbing wholesaler to find it but it does a very good job of cleaning,dissolving,and deodorizing. It smeels to me like the old pine oil cleaners. Follow instruction on the can and use regularly for best results. Thank you.
Posted on Jan 20, 2011
Saniflow runs, but not straight after flushing
This will definately help.
Jan 30, 2013 | Saniflo Home
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
Toilet wont flush
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
After flushing, the toilet keeps running. However, if I turn off the water supply, and then turn back on, the toilet stops running until the next time it is flushed. Toilet makes a
It could be the type of flap you are using. I would suggest you try a different shaped flapper (a cone would work best) and if that doesn't do it, put a new kit into the unit, because it could be that the float system is sticking causing it to continue running.
Jan 10, 2012 | Toto Carlyle One-Piece Toilet Toilets
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
Why does my macerater give off a smell some times when flushed and what cleaning agents can be used
Jan 20, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow is running constantly.
Shut the water off to see if it stops running. if so the flush valve seat has calcium build up and needs to be cleaned start by using CLR to help dissolve the calcium. If running water is not the problem, the mercerator is jammed with paper and will need to be cleared.
Mar 27, 2009 | Saniflo & Saniplus& Macerator Pump
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Saniflo & Saniplus& Macerator Pump  Logo
250 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
