Question about Skil 10" Table Saw 3400
Skil Tablesaw Model 3400 Type 1 - No power-Repl reset switch and still won.t power-up
Just started to cut a 1in, pine board. Power came on and almost instantly went dead. Reset switch would not reset so I replaced that. Still no power.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
Did it short out or are you using the correct voltage?
Posted on Dec 02, 2012
3 Suggested Answers
  • 59 Answers
SOURCE: My Skil Saw 10 will not start now.
depends wether the saw is belt driven or gear. just because you cant hear the motor doesnt mean its not running.
Posted on Apr 25, 2009
  • 33 Answers
SOURCE: bought model 3400 skil table saw. have no manual.
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Posted on Jul 19, 2009
Skill saw table saw model 3400.Bypassed on off switch still no power?Does motor have a breaker on inside?
I have the same saw.
Sorry but this question has to be asked, is the AC (Alternating Current) outlet working/ an live outlet? Had to ask.
If outlet is good move on to the next steps.
Take an ohm meter / continuity meter.
With the AC power cord unplugged from the AC wall outlet.
Place the two test leads from the meter onto the plug prongs .
With the switched closed/ON, you should get zero ohms (or very low, close to zero/ continuity).
In your case you probably will not have any continuity because it doesn't turn on.
Now comes the fun part trying to find the problem/ open connection.
Lots of possibilities.
  1. The AC cord could be bad at the plug end.
  2. The AC cord could be bad at the point entering the table saw.
  3. The motor could be bad.
  4. The brushes in the motor could be bad.
  5. The field winding in the motor could be open/bad.
The plan is to ohm/continuity check the path of the power going to the motor, (both sides of wiring).
While meter leads are on the AC plug end, wiggle the strain relief ends. You have an intermittent connection.
TROUBLE: SAW WILL NOT START
PROBLEM 1. Power cord is not plugged in.
2. Fuse or circuit breaker tripped.
3. Cord damaged.
4. Burned out switch.
REMEDY 1. Plug saw in.
2. Replace fuse or reset tripped circuit breaker.
3. Have cord replaced by an Authorized Skil Service Center or Service Station.
4. Have switch replaced by an Authorized Skil Service Center or Service Station.
May 25, 2016 | Saws
What is gas to oil mixture for skil 1634 chainsaw
Usually these type of machines use a 32:1 or a 40:1 ratio but I do not know what the manufacturer of this particular machine calls for. Better oils can use a lesser amount of oil In any case use the best il you can find.
Oct 05, 2014 | Skil 16" Oregon Chain Saw Repl. Chain...
Do parts for a model 3305 skil tablesaw interchange with a model 3400
numerous parts should. When you get to the armature and spur gear, then it gets a bit iffy.
Feb 13, 2012 | Skil 10" Table Saw
New SKILSAW 5995 used once to cut 1/4 inch plywood, no problem. Several months pass and I went to cut a pine board, the blade touched the wood and stopped. I recharged the batteries and tried again, two...
Did you fully charge both batteries before using them the first time? If not then they may not be able to hold a charge. It sounds to me like the batteries are either dead or defective as obviously the saw now doesn't have the juice to cut the board. If it's still under warranty take it back and get a replacement. Also, how powerful are the batteries? Even an 18V saw will struggle sometimes cutting a 2x4, they just don't have that much power. The plywood is easier to cut obviously.
Aug 12, 2011 | Skil Saws
Can I order from anyone a new fence for a skilsaw fence model 3400.
Skil is part of Bosch Tools. You can go to their website. https://www.boschtoolsservice.com. Click on "Search for your tool" under tool model # type in 3400. I believe the fence you are looking for is part #860 and costs about $34.00, however I would recommend calling them because there were so many variations on the 3400 that there may be more than 1 fence for model 3400 and you want to make sure you get the proper one.
Oct 09, 2010 | Skil F0123400AB Na 10" Table Saw, 15 Amps
Skil 10 tablesaw nut keeps getting loose--- tighten nnut start to cut blage stops- check nut it is loose again---- is the the nut cracked and what size is it
It's 5/8-11. If it's cracked you should be able to see the crack with a flashlight when you have tightened it up pretty hard. It would also be kind of mushy to tighten, rather than suddenly stopping.
Jun 18, 2010 | Skil 10" Table Saw
I need an owner's manual for Skil 10" table saw. Any help?
What is the model number? Its probably a 3400 model, just call 877-754-5999 and you can have Skil send one out for free.
Feb 17, 2010 | Skil 10" Table Saw 3400
Apr 25, 2009 | Skil 10" Table Saw 3400
Skil bandsaw
Well said John. We have all purchased a cheap tool along the way only to find that it was truly made only to be sold, not to actually use. On the other hand, some quality tools are so very expensive. I have finally concluded that a tool I only use once in a blue moon is best to rent, not purchase outright.
Mar 03, 2009 | Skil 3385-01-RT Factory-Reconditioned 9"...
Table saw skilsaw model number 3400 15 amp
What you are describing sounds like the power is being interrupted somewhere. In my experience, this is usually casued by a bad switch. Try replacing the trigger switch.
Dan
Oct 19, 2008 | Bosch 7 - 1/4" Skilsaw Circular Saw
Skil 10" Table Saw 3400 Logo
297 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
