I have a toshiba CT-90369 remote not working. and need a code for a universal remote? lost the manual. where can i find the codes? toshiba website no help!
    Top Expert:
  • Televison & ... Master
  • 34,196 Answers
If we knew what brand of universal remote you want to use to control your Toshiba TV, maybe we could help
Posted on Dec 01, 2012
  • 127 Answers
SOURCE: programming my toshiba universal remote
http://www.tacp.toshiba.com/tacpassets-images/models/27AF45/docs/27AF45_om_E.pdf
Scroll down to the remote section page 12 -13 its in there... I have this same remote and just programmed it.. Good Luck to you!
Posted on Nov 06, 2008
aprmaejun
  • 97 Answers
SOURCE: philips remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 22, 2008
AvioriX
  • 689 Answers
SOURCE: GE Universal (JASRM24912) Remote Control
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
Posted on Jan 18, 2008
IrishDruid
  • 2712 Answers
SOURCE: toshiba ct-90275 code for direct tv d10
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 18 Answers
SOURCE: I can't find a manual for the toshiba ct-90251
check this out : http://remotes.com/remotes/documents/Toshiba/CT-90251.pdf
I found it on this website : http://remotes.com/store/codes_original.html
hope this info helps you.
Posted on Sep 21, 2009
I need universal remote code for toshiba CT-877
Universal remote setup codes for Toshiba Brand TVs are > 0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Dec 23, 2012 | Toshiba CT-877 Remote Control
I need the code list for a Universal remote Toshiba CT-90158
Try to enter code 664 it is the only code in my book for a JVC dvd player
Aug 15, 2012 | One For All Televison & Video
Codes for toshiba universal remote number ct-90302
You need the sheet that came with the remote. If the manufacturer's codes do not work with your ??, then you need a more modern remote. The codes must ALREADY be in the remote to be used. The code is part of the REMOTE.
http://www.tvcodes.com/ may have the code for you.
Mar 26, 2010 | Toshiba CT-90157 Remote Control
Getting toshiba ct-852 to program
This remote is programed by holding the CODE button and pressing the electronic button that you want to be programed. (For example press and hold CODE and hit DVD.) After you do this you have 10 seconds to input the 2 digit program code for the electronic you want programed. If your manual doesn't have these codes you can This One on page 13.
Hope this helps
Jan 26, 2009 | Universal Remote Control DIRECTV Universal...
Need the tv coes for my toshiba tv
I have a older Toshiba TV CE20F10,but I lost the codes tomy TV,Ineed them.Tkank you
Dec 12, 2008 | Toshiba CT-90157 Remote Control
Programming my toshiba universal remote
Oct 12, 2008 | GE 84918 Remote Control
Lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
Nov 07, 2007 | RCA Universal Remote Control
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Oct 02, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
288 people viewed this question
Top Televison & Video Experts
Electro Med Services...
