Question about Neff B1421 Electric Single Oven
Opening door catches
Door catches have closed while door off - how to release them?
    Sergeant:
  • 389 Answers
Pull down the door hinges there is a slot turn it and it will lock the hinge put the door back on turn the slots back
Posted on Dec 02, 2012
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
Trying to remove oven door kitchenaid model YKESS907SS00
Without seeing it don't know which you have open the door look at the hinges if you have what looks like little levers that fold down then raise them up fully start to close the door slowly they will catch the levers raise the door slightly and pull out if you have the other style open the door fully look at the hinge you should see a small hole insert a small screw in each hinge follow same procedure.
Feb 04, 2014 | Ovens
My general electric XL-44 will not go out of self cleaning position after my using it to clean my oven.please help
Let it cool down completetly only then the lever is released to open the door. Or open the top hood of the oven reach for the switch and release the catch to operate the lever to open the door.
Nov 30, 2013 | Ovens
Clean inside door
take door off oven, usually has a catch on hinges when fully open then close to 80% and take off.
Lay door flat on bench with handle overhanging bench.
disassemble inner and outer.
CLEAN
reassemble.
reinstall.
Oct 14, 2013 | Miele H4082BM Oven
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
My whirlpool double oven lower door won't stay closed all the way. model RBD305PD810. is there an adjustment that is needed?
If it is a drop down door, then you need to replace both door hinges, if it is a door that opens sideways, then it is probably the door catch, or door striker that needs to be replaced.
Please rate my solution.
Thanks.
Nov 01, 2009 | Whirlpool RBD305PD Electric Double Oven
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Top oven door glass has smashed
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Jan 01, 2009 | Fagor Ovens
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Oct 27, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Trying to remove front doors from Frigidaire Double oven.
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the locked position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
The door can now be disassembled and cleaned.
Jun 22, 2008 | Frigidaire Ovens
Neff B1421 Electric Single Oven Logo
95 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
