Question about Canon imageRUNNER 5000 Copier
How to enable the meter count of canon iR600n
  • Canon Expert
  • 287 Answers
Hmmmm. I have to assume you merely wish to view the meter. The only way I am aware of for an older copier such as yours is to open the front door and view the ANALOG meter which is @ the left upper quadrant of the covers. This count I believe can also be obtained in service mode but we wont go there.
Posted on Dec 02, 2012
3 Suggested Answers
SOURCE: Meter reading on Canon PC 1061
How do you fix the roller of a canon pc 1061 copier? Can I get the owner's manual online?
Posted on Jun 25, 2008
Cogz
  • 1326 Answers
SOURCE: Where to read the meter count?
Open the front door of the copier, look on the inside pannel of the copier, it should be right above the fixing unit.... Good Luck
Posted on Apr 02, 2009
Meter reading seting canon ir 2200
There is a botton on the control panel that say's "Counter" press the botton and that is the meter count.
Nov 01, 2011 | Canon imageRUNNER 2200
Is there a manual meter to get the copy count on a Canon IR6570 ? I cannot seem to locate it.
there is no manual meter. if wanna have the print out of meter then u have to enter the service mode and the press MISC_P to print the meter
service mode
additional function * additional function
Jun 29, 2011 | Canon USA - COPIERS - IMAGERUNNER 5570...
How do I read the meter on a Canon 3025 copier/
Hello colleenm,
The button that will display your meter is located on the operator control panel that is at your fingertips. Locate the large green START button. At about the 2 o'clock postion to the START button is the STOP button, orange colored. Now look "slightly higher and slightly to the right " and you will see a small "Counter Check" buton. Press it and the meters will be displayed. You will see at the top of the list a meter labeled "101".That meter tells you how many sheets of paper have successfully exited the copier regardless of the size of the paper. My company asks that we set the devices up so that they count 11x17 paper as 2 counts as it is basically 2 sheets of paper. The meters that will be listed below meter 101 are usually unused unless a technician has customized the meters that reside there as we do. I hope this helps. If it does , please let FIXYA know. :-) SPINAL
May 13, 2011 | Canon ImageRunner 3025 Black and White...
I need to know how to print out a hard copy of the meter read on a Canon Imagerunner 3035 copier??
Hello mhitt,
Even though you have a pretty new copier, the ability to print the meter reading is not available. I know it's crazy since other copiers have been able to do it for years. Only the most recent models of Canon copiers have this ability. To print the meter readings for your copier would require that you go into SERVICE MODE and print a report that has several pages of **** and if you know what you are looking for you can find it.You could use the REMOTE USER INTERFACE (RUI) and view the meter and do a "screen print". I know it's not a happy answer but its correct. I wish you well. :-) By the way, the main meter reading (designated 101) is the count of sheets of paper that have successfully exited the copier regardless of size. My company uses meter "102" which counts 11x17 as 2 clicks on the meter. You probably cannot see this meter unless a service tech programmed it in.
Mar 17, 2011 | Canon imageRUNNER 3035 Black and White...
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
When checking the meter reading on my canon ir c5185, there are the following codes before the totals: 101 102 108 230 321 322. Can you tell me their meanings?
Hello joe,hope you are well.Canon copiers have literally hundreds of "meters " that the device is constantly monitoring.Things like the number of 11x17 scans,reports printed,incoming faxes,outgoing faxes,prints at 600 dpi....etc.Its wild.The device is capable of displaying to the customer a total of six meters.The displayed meters may be customized for the customer by a technician as per the customers request or needs.Each meter is named by a number,for example "101".That particular meter indicates the total of how many sheets of paper(regardless of size) that have successfully exited the machine.102 meter indicates the total number of sheets that have been output using 8.5 X 11' as the basis.So a sheet of 11x17 paper would increment the 101 meter once,but the 102 meter would "click" twice.For billing purposes my company keeps an eye on the 102 meter to maximize profit,as it should be.Now how Canon determined the display of the other meters you see is a mystery.Again there is a meter named 958,which is the number of documents scanned to the MAILBOX. So, to completely answer your question: 108 is the total black and white copies made regardless of size.230 is just color and monocolor regardless of size.321 is{your gonna love this one}color prints on 11x17.322 is color prints on 8.5x11.So there ya' go! TMI city!!! Hope this helps.
Jan 07, 2011 | Canon Office Equipment & Supplies
Apr 01, 2009 | Canon Office Equipment & Supplies
External Control and Scan counts of DR-9080C
THe scan count is available in the control panel (under scanners...) and if the user is a non-administrator, he/she cannot reset it.
Canon 9080C permits installation of a mechanical counter inside the scanner. This can help you track the scanned quantity.
The way your question is detailed, I am sure you must be aware of these facts!
S. Mohan
Mar 16, 2009 | Canon DR-9080C Path-Through Scanner
Need to get the meter count on my canon 6545 copier
The meter is located on the inside left hand side right above the fixing unit.. That is called the hard counter. There is also electronic counter that can be seen in service mode, but they can be reset at any time.
Apr 25, 2008 | Canon NP 6545 Copier
Feb 27, 2008 | Canon PC1061 Copier
Canon imageRUNNER 5000 Copier Logo
26 people viewed this question
old marine
old marine
