I don't know what the Hicon TV power plug looks like? and I do not which to plug it into?
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: i don't know which is right x-sus & y-sus or power supply 12/22 codes
If they are on left and right sides look from front of set--if not Google the model for a service manual which will have a pictorial showing which is which.
Posted on Jun 13, 2012
What volts and amps do I need For the hicon 1903sd
What component are you referring too for volts and amps ?
There are hundreds of components inside your TV. Most components have it written on them.
What is the symptom or error you observe.
Apr 22, 2016 | Televison & Video
Mitsubishi WD-73735 will not turn on and there are no lights on front. The power supply was replaced, and is brand new. I fix HDTVs, and have had very little problem resolving other issues with other TVs....
if you have no lights come on the front of TV, you definitely have a power supply issue. Don't know what previous servicer did, but I would be looking at ALL wires & connectors.
Feb 10, 2013 | Mitsubishi WD-73735 Television
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Need info on a Recoton Antenna -need to know DC imput amt etc.
that coaxial cable with male end has to be connected to '' tv antenna in '' connector of your tv ....... to find whether any ac adaptor is required for your indoor antenna just observe all sides of that antenna ....... if any male or female connector is there means definitely it requires adaptor ( size will be smaller then coaxial cable's male end connector ) .... click 1 st link to see whether your antenna is like that ..... if no means check 2nd link ............ once your antenna's model no is identified it will be easy to clear all doubts ....... it may require 9 volts or 12 volts adaptor ..... Recoton's universal adaptor is available ( check 3rd link ) ...... so check these links & tell us .... then we can find exact details of your antenna .......... if possible take picture of your antenna (all sides) & email to me (sathyavijayasarathibabu@ymail.com ) ....
http://www.orbitcommunications.com/cyberstore/product.asp?PID=TV-800
http://www.google.co.in/search?tbm=isch&hl=en&source=hp&biw=1024&bih=527&q=recoton+tv+indoor+antenna&btnG=Search+images&gbv=2&oq=recoton+tv+indoor+antenna&aq=f&aqi=&gs_upl=0l0l0l3719l0l0l0l0l0l0l0l0ll0l0&sout=0&sa=X&ei=Ze-2Tq7BIM7HrQf4vbjcAw&ved=0CDYQxxQ
http://www.futureshop.ca/en-CA/product/recoton-universal-ac-adapter-ad500-500ma/80730005.aspx
Nov 06, 2011 | Televison & Video
My insignia tv has "store
Hello chadprid24,
you should be able to change it by selecting menu then setup followed by plug & play. Look for setup wizzard. If not look for reset to factory defaults in the menu screen again. I hope this helps, if not give me a feedback. Good luck.
- Joe
Aug 31, 2011 | Insignia Televison & Video
SHARP LC-37SH20U GREEN LIGHT BLINKING BLANK SCREEN NO SOUND HAD A POWER OUTAGE & NOW IT WILL NOT TURN OFF UNLESS YOU UNPLUG FROM POWER SOURCE & IT WILL NOT GIVE PICTURE ABOUT 2 YEARS OLD CALLED...
The tv Tuner signal board is it shorted and the caused,that the board where ur tv signal cable wire plug in for tv broadcasting air tv stations.This tv Tuner signal board must be replaced,u can do it if u some basic mechanicals skills like take things aparts and putting it back together again?Yes?U tries websites like Shopjimmy.com,Ebay.com to buy a whole tv refurbish tv Tuner signal board for the replacement.Or must get a priced quote by tvs repair shops,replaced an repair by thems.
Jul 26, 2011 | Sharp LC37SH20U 37 in. LCD Television
What is the average watts power of philips 14 inch tv so as to get the correct power inverter to go from 12 volt batteries to 240v mains. We are about to change over from analog to digital and I already...
If there is a current amount ie. 2.4 amps or whatever the label says, you multiply the volts by the amps to get watts. add about 20% for surge current when you first turn the TV on.
May 04, 2017 | Televison & Video
Hi there I am living in South Africa and is in desperate need for a remote control for a Hyundai HLCD-019, 49cm LCD tv. I have tried most universal remotes and none of the codes are compatible. Please...
You don't actually have a Hyundai, you have a Hicon that was badged as a Hyunday in your country - they do that regularly. The only universal remote that supports your Hicon is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
May 24, 2011 | Televison & Video
I was watching tv and the tv turn off itself than no ligues no power and i try to turn on again and nothing happen what i should do?
Good day!
The problem of your TV is the power supply board.
Please follow this procedure to fix that problem:
  1. Remove the back cover of your TV.
  2. After that,look for the power supply board.
  3. Next,check the input voltage of the power supply using multimeter tester (range in AC).If the power supply don't have input voltage,replace the power cord.
  4. If the power supply board have input voltage,next is check the output voltage of power supply it should have 5vdc for the system board,12vdc for the sounds and 24vdc for the back light inverter.
  5. If you don't have output voltage of the power supply.Please check the fuse if busted and the power transistor if it is shorted,replace it with the same type,ratings and value.Also look for any leak/bulged on the top capacitor.
  6. After you done this steps and you found and replace the defective parts.Plug-in your TV and power it ON to test if it is OK.
The power supply looks like this:
If this solution will be help you to fix your problem,please don't forget to vote and rate my answer.Thank you for using FixYa and good luck.
May 08, 2011 | Vizio L37 Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
