Question about NAD AMC 3020 Stereo Integrated Amplifier
Only one channel works on nad 3020
No audio from one channel
  • Ker Anderson Dec 01, 2012
    Hi - Anyone got any suggestions on how to repair a NAD 3020 which has stopped working on the left channel?
2 Suggested Answers
gopakumarg43
  • 74243 Answers
SOURCE: I have just bought a
Hello
You have replaced your old NAD 3020 with NAD C326BEE. You are using the old speaker system with the new NAD 326 too. The Amp you replaced [NAD 3020] have only 20W/channel output power, and the present NAD C326BEE has a rated output power of 100W/channel. Both specifications are for 8Ohms speker impedence. Your old speakers haven't got the power handling capacity for the new Amp. That is why you hear it very clear at low volume levels and disorts at high volume levels. Distortion is not due to the Amp, but with the speaker you uses. You have to replace either speaker system or the speaker in which your old speaker box is fitted, with a new one, whcih can handle the power of the present Amp. OK.
Posted on Dec 16, 2010
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
How can I turn off the sleeping mode on the nad 3020
You may want to try this if you need a manual or other info.
http://www.hifiengine.com/manual_library/nad/3020.shtml
May 10, 2014 | NAD D 3020 Hybrid Digital Amplifier
NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Jun 26, 2009 | NAD C372 Amplifier
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
May 03, 2009 | NAD C325BEE Amplifier
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
Right Channel Not Working
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Apr 26, 2008 | NAD T752 Receiver
NAD T955 amp has dropped a channel, when i turn it on the led starts off blue instead of red, when the other channels change to blue from red it emits a loud POP noise from the lost channel. No noise comes...
Hello.I know the post is old but i had the same Amplifire NAD T955 with the same problem.I send my Baby to a Service in Austria and they can easy repair it.Im very happy again,it works nice.If anyone had this problem contact them.Harlander GmbH in Vienna.Homepage reparatur-service.at.
Greetz TommyS
Apr 15, 2008 | Audio Players & Recorders
One audio channel is not working
1.check whether the audio.rca jack cable is good
2.check Rca jack connector
3.there might be a problem in your stereo audio processing circuits
4.Contact service centre for further rectification
Nov 21, 2007 | NAD L40 CD Player
NAD AMC 3020 Stereo Integrated Amplifier Logo
80 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
