Question about Lasko 3520 20-Inch Cyclone Fan
Lasko 3520 20-Inch Cyclone Fan how to remove fan blades for cleaning
4 Suggested Answers
SOURCE: lasko tower fan with ionizer
Try a can of compressed air. It's impossible to get inside.
Posted on Jul 22, 2008
red54eyejp
  • 25 Answers
SOURCE: blade broke where to get new one
You can call by phone Lasko customer Service and Replacement Parts......1-800-233-0268.......givi them FAN info and they will ship you part..........................Also check, your product may be covered under WARRENTY or may be listed under product recall .......either will reduce your COST .....
Posted on May 11, 2009
  • 5 Answers
SOURCE: lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Posted on Jun 11, 2009
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
How do I take off to replace a lasko cyclone 3542 fan blade ?
Bex,
THose usually just pull off. You will have to pull hard because there is a spring clamp that they sometimes put around the inside hub of the fan. If there is a clamp, you will need to transfer that to the new blade. Hope this helps!
Jun 13, 2015 | Lasko Dryers
How do i take apart my lasko cyclone fan to clean the inside of it
You may need to UNSCREW the front half of you fan guard plastic casing or depress it in a few place if you see notches on the cage itself. Remember the knobs you will be removing to take the blades off to clean will be threaded opposite, one will screw off and on clockwise then other counter clockwise. Be sure FAN is UNPLUGGED BEFORE YOU open it up. Lay all parts in bathtub, Spray with Cleaning foam, pour lots of water over to clean all sides, then let drain and dry in bathtub. Less muss and fess this way!
Aug 09, 2014 | Lasko 3510 cyclon Floor / Box Fan
High pitch squealing when i turn on fan
bearing gone or rotor blade scraping against outer cover
Dec 12, 2013 | Lasko 3520 20-Inch Cyclone Fan
How do I take the front cover off so that I can clean the blades etc of dust?
You can blow the whole fan clean with compressed air or a compressor. It does not require removing the cover. The cover comes off with a twist and a pull, but does not stay on well afterwards, so I don't recommend removal. Farmerbear at FixYa.com
Sep 29, 2010 | Lasko 3520 20-Inch Cyclone Fan
I have a Model #3510 Lasko Cyclone Fan and the blades are dirty
Steam works great, otherwise you can use a degreaser and hose it off. Make sure you let it dry completey and then some before plugging back in.
Aug 26, 2009 | Dryers
Removing fan blades
Joey Temal is right. After removing any small metal retaining clips (which are obvious and easily removed), you have to pull down ridiculously hard to get the fan blade off. Alternate short jerky pulls with steady downward traction.
Jun 12, 2009 | Lasko 3520 20-Inch Cyclone Fan
Lasko 3520 20-Inch Cyclone fan - disassemble fan for cleaning?
How do I clean my Cyclone or Air Companion™?
Lay the fan face up on a flat surface. The front grill should be facing you. Remove the screws from the rear grill. Place a flat-head screwdriver into the gap between the front and rear grills. Pull the front grill towards you, exposing the fan blade. Do not remove the knobs on either side. Then, wipe the blade with a soft, damp cloth. Use a mild detergent if necessary. Be sure not to touch the motor. Click here to download product instruction sheet.
Jun 08, 2009 | Dryers
Lasko 3520 20-Inch Cyclone Fan Logo
190 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
