Question about Western Digital Caviar SE16 WD2500KS 250 GB Hard Drive
Hadrive Making Knocking Sound, does not function
I have have my 250 Gig Western Digital harddrive for a couple of years now. From about two weeks ago I trien connecting it and it became extremely slow to response, causing my PC to freeze. Eventually it started making a knocking sound and would not load as a drive. I would get the inidcation that a USB Mass storage devise is connected, but no further activity i.e. another drive or accessibility. I am running windows XP SP2 and have tried accessing drives from other machine, both desk tops and lap tops. The same problem still exists. Anyone out there who can advise or has a solution?
  • 95 Answers
Try to disconnect SATA/IDE cable leaving just the the power and see how it goes. If still clicks try another power supply unit in another computer. If still doesn't help there's an option with freezer but it rarely helps.
Most likely the heads are gone bad and you need expensive professional data recovery if data really matters. Quite a common problem with WD :(
Posted on Oct 21, 2008
  • 23 Answers
The knocking sound means that the 'arm' on the inside of the harddrive is going out. unfortunately there's nothing you can really do about it, you may be able to get your data off, but otherwise I'd say it's trash. sorry
Posted on Jun 07, 2007
My Western Digital My Book Essentials will not power on
IT appears that the HD is dead
Take it to an IT repair shop and have it checked out
If that is the case , replace it with a sshd unit as there is no moving parts like you have now to wear out
it powers up faster as well
Dec 07, 2015 | Western Digital My Book Essential 2TB USB...
I bought this HP Pavilion a1610n and it had a dead 250 gig sata harddrive(western digital).I installed a new 250 gig harddrive western digital sata drive in this computer(motherboard is a A7VBX-LA)I cannot...
Here are the original drivers for Xp on top and Vista on bottom not sure which you have or need.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
Sep 14, 2011 | HP Pavilion a1610n PC Desktop
My western digital 320 gig external hard drive stopped working all of a sudden. it has not been physically damaged. when plugged in the lights just blinks.
you told that it has not been pysically damaged than why light just blinks ok first you see the cable is in good condition. next plugin you hard disk to your computer and listen if any kind of sound coming through your hard disk (sound is like tee tic) if the sound out comes like what i said some way it stuck or damaged let me know if it works
Aug 12, 2010 | Western Digital (WD3200JS) 320 GB Hard...
My computer does not recognize my WD external drive
You've tried different USB cables; so, that cannot be the problem.
You've tried connecting to different computers; so, the problem is _not_ your computer.
What's left is "inside" the case:
* the USB-to-disk-drive adapter,
* the disk-drive.
Open the case, and remove the disk-drive, and connect it as a "slave" drive to some computer.
If it is detected, then the USB-to-disk-drive adapter that has failed.
If it not detected, then the disk-drive itself has failed.
FInd the serial-number on the Western Digital disk-drive, and enter it onto Western Digital's web-site, on the "check-warranty" page. If it's older than 3 years, the warranty probably has expired, unless you were "lucky" and got a 5-year warranty.
Western Digital has a "Customer Loyalty" program -- just buy a new Passport through their web-site, and cite the serial-number, and you'll get a significant discount on _their_ price (could be higher than your local retail computer-store) for a new (probably larger) Passport.
Apr 05, 2010 | Western Digital WD Passport 250GB Portable...
I accidentally droppped my brand new 320gb WD Passport now it isn't working it lights up & it has a tick sound then stops spinning...pls help.. :(
Most likely you have damaged the actual harddrive, the ticking sound is NOT A GOOD HARDDRIVE SOUND! Contact western digital and tell them that your NEW harddrive is making this sound out of the box DO NOT MENTION DROPPING IT. They should RMA it as long as you really did just buy it.
Oct 04, 2009 | Western Digital Passport 320GB External...
Clicking/knocking sound and feel when shifting & smell
first check the clutch hydrolic fluid. If it's low or leaking, it may not disengage the clutch completely causing the disk to drag (and smell) The knocking sounds like you're loosing the thowout bearing and/or possibly the disk (there are cushion springs that may have come out of place). Take it to a transmission shop that does free diagnosis. anything other than fluid-related is going to be pricey.
dont forget to rate ... and dont shoot the messenger
Jan 03, 2009 | 1999 Volkswagen Beetle
Western digital passport essential harddrive 250 gig
It assumes that the drive C is the drive you booted from or the "root" drive. You must make it something other than "C". Try putting in a camera card, hooking up an external drive or other device that the computer makes drive "C" THEN hook up your passport. It will be "D" or "G" or something other than "C" and it will work.
Oct 24, 2008 | Western Digital Passport WDXML800UE...
Western digital my book 500 gb
Cheek your system os is not suportion the hard drive increase the ram and try in xp only
Jul 10, 2008 | Western Digital My Book Essential Edition...
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Western Digital Caviar SE16 WD2500KS 250 GB Hard Drive Logo
337 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
