Laptop icons and display is too large - Computers & Internet
  • 564 Answers
If you right click on the desktop and choose properties (if using XP) or personalize (if using vista or windows 7).you can change the settings
Posted on Dec 01, 2012
How do i reduce the text and icons on my laptop display/screen
Assuming you have a Windows system:
  1. First make sure you don't have the type size and icons set to a large size. Right click on your Desktop and choose 'Personalize'. Then in the lower left choose 'Display'. Make sure that you have selected 100% as the size of text and icons. If you have, proceed to #2
  2. Make sure that you are displaying at the native resolution on your laptop. If Windows doesn't have the right software drivers (instructions) for the display it will use some generic drivers which will work but will make everything appear large and potentially slightly fuzzy. Verify the potential resolution of your laptop with HP by looking up the model on their website and then checking the screen resolution. Then right click on your Desktop and pick 'Screen Resolution' from the context menu. Verify that the resolution is the same as the HP's listed resolution. If not, change it to match. If you can't change it to match that means you don't have the correct video card driver installed on your notebook. Go to #3
  3. To install the correct video driver for your notebook, go to the HP Support site and click on 'Detect my product'. This will install some HP software that will recognize your system and load the appropriate updated software drivers for all components. You want to specifically find 'video drivers' but it will probably be OK to let others found by the website be installed. Install the video drivers and then if the screen isn't displaying at the correct manufacturer resolution, go back and repeat the instructions in step 2 to manually set it.
That should get everything displaying at the correct size.
Drivers Downloads
Feb 18, 2015 | HP Pavilion Computers & Internet
Start up screen has strange large icons and lettering
Are you in "SAFE MODE"? if not it only a display setting, it can be changed.
Oct 30, 2012 | Lenovo Computers & Internet
How to change the size of desktop icons
Right click on the Desktop to bring up Display Properties - Click on Appearance tab - then click on Effects button - and then tick Use large icons box - click OK - Click Ok in Display Properties to make the change.
Jun 19, 2012 | Acer Aspire 5742Z6682 Notebook
Hi I connected an "S" cable from my laptop to my
Thank You Mr. David,
For choosing my services.
I will try my level best to help you,
First start with very basic Troubleshooting steps
1. Switch off both devices.
2. Make connections S-Videos
3. Now switch on Laptop (As you mentioned its dell)
4. Now switch on TV or monitor.
5. Now hold (fn key) and simultaneously press f8 or f7) f8 for dell. (key which contains display icon on it).
6. Fn and f8 key helps in toggling displays in 3 modes-
7. Laptop display
8. Monitor /TV display
9. Both of displays
If you are Using Windows 7 then follow these settings after above troubleshooting steps
  1. Click "Start," access the "Control Panel" and then select "Appearance and Personalization." Find the option that says "Adjust Screen Resolution" and click once. A small window displays with two monitors labeled "1" and "2."
  2. Click on the "Identify" icon and a large "1" appears on one monitor while a large "2" appears on the other.
  3. Select the drop-down menu next to "Multiple Displays." Select the "Extend these displays" and click apply. The desktop is now extended. Adjust the "Resolution" and "Orientation" to complete the customization.
  4. Control Panel\All Control Panel Items\Display (You can choose magnification of your screen. (Medium-100 % recommended) check and set it to medium.
Now Let Me know the status and Exact problem You are facing right know.
Thank You Regards
Sunil Pratap Singh
Feb 05, 2012 | Dell Computers & Internet
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
Font and icons very large
control panel display
then settings you need to move the settings bar to more you probably want it set at 1024x768
then click apply
let me know if this helped otherwise it may be your driver
Jan 15, 2009 | HP Pavilion dv9000z Notebook
Dual monitor setup
Assuming you are using Windows Vista:
All you have to do is connect your laptop to a monitor via a VGA port (located on either the side or at the back of your laptop - it's the port with about 15 holes).
Once connected , you will need to configure how your 2nd monitor will function - as an extended or duplicate monitor. To set this you will need to go to Display Settings > and select your option.
Sep 28, 2008 | Compaq Presario 700 470024-192 Notebook
Windows vista lare icons and text
In changing the icons to normal, did you reset the screen resolution? If not, set the resolution lower, apply, then reset it back to the original (usually 1024x768), then apply.
Aug 12, 2008 | Toshiba Satellite P105-S6207 Laptop
Text size very large after update
check display drivers are loaded if not load display driver it will work.
Jul 10, 2008 | Computers & Internet
Display reverts to Extra large icons and font
well..hmmm..sounds like your display settings are a bit odd..if you want, we can do an E Housecall. send me a note through my profile information
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
