Question about Fellowes Powershred SB-87Cs Shredder
A 'band' has come unstuck at the entrance of my Fellowes paper shredder.
I have a Fellowes paper shredder. There is a very fine 'band' on the floor of the slot where the paper is inserted. It's approx. 5mm thick and runs across the whole slot. In my case the band has come unstuck. What is this band? What does it do? Where can I find a replacement?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have the exact same problem!! I'm wondering if you ever found a solution.
Posted on Oct 16, 2013
fellowesrep
  • 102 Answers
SOURCE: Fellowes Shredder keeps running
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
SOURCE: fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Posted on Jul 12, 2008
SOURCE: Fellowes crosscut shredder does not shut off
Best to use the alcohol/cotton swab recommendation. When I first called Fellowes about cleaning the sensor, they told me never to spray compressed air into the shredder throat, but without much explanation. Later I discovered that the instructions on some of the compressed air cans specifically warn against using them to clear shredder sensors, as the flammable accelerant can leak out when the can is held at an angle and possibly ignite if a spark is generated by the machine.
This link will take you to the Fellowes FAQ page:
http://fellowes.com/fellowes/site/support/support_troubleshooting.aspx#dm12c
On the page click on "How do I clean the sensors on my (model) shredder."  I depart a bit from the instructions in that I don't replace the two screws on the throat guide. That way, I can simply slide the media guide toward the front of the machine, lift up the throat guide and do my cleaning. Much faster and, in my opinion, not having the throat guide screws in does not seem to pose much of a safety issue.
Posted on Jan 22, 2009
Pulkit558
  • 472 Answers
SOURCE: my fellowes paper shredder is
Instructions
Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
Posted on Jun 19, 2010
SOURCE: Where can I find gears for a fellowes p57c paper
Not sure where ur located, but there is a small store in a town called Manchester, TN called Evelyns Office Supply. They may be able to mail you one. Good luck!
Posted on Mar 20, 2011
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Blow some canned air down into the feed slot to clean the sensors.
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
The Auto-On switch does not work. I have to manually turn the shredder on and then feed paper into the slot. It feeds and shreds the paper just fine, but I have to manually turn it off to stop it. All of...
There must be an auto-on/off sensor in the middle of the paper entrance slot - either mechanical or optical.It needs to be cleaned from any obstructions like paper chads or paper dust.It this doesn't help,the sensor maybe defective and it needs to be replaced.
Oct 02, 2009 | Fellowes Powershred SB-87Cs Shredder
Was shredding papers and unit stopped,and will not take anymore papers,but it will still go in reverse Fellowes model w11c
Make sure you use a can of compressed air and cotton swabs to cean the entrance and exit sensors.
Jun 11, 2009 | Fellowes W11C Confetti-Cut Shredder
Shredder won't grab paper
there has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Sep 05, 2008 | Fellowes PS60C-2 Shredder
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Fellowes Powershred SB-87Cs Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
