Question about GE Refrigerators
Fridge slowly gets warmer and stops working
The fridge seems to get warmer over a period of weeks and then stops getting cold. The freezer vents collect a large amount of ice in a short time restricting the vents. When cleared, the fridge gets cooler again, for a while.
  • stevedamm Jan 11, 2009
    Thank you very much. I'm handy enough to instal simple plumbing and fixtures, do you think I can handle these items?
    President:
  • 2,559 Answers
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Posted on Jan 11, 2009
  • Randy Hough
    Randy Hough Jan 12, 2009
    just make sure you disconnect the power and you should be able to do it.
    Defrost timer: 2 screws hold it on and the wiring is a clip you unplug.
    Element:Held in with 2 metal clips and has 2 wire that lead to connectors
    Thermostat:one metal clip and 2 wires that lead to connectors
Problem, fridge over a period of a few weeks or less goes from really cold to not so cold with ice buildup on the ceiling of the fridge section beneath the freezer compartment which itself does not ke
Hi, This will happen if you have a faulty defrost timer or the the heater is not working when it goes into defrost. The reason its not so cold after a week or so because the ice builds up & doesnt run efficently which is why when you switch it off & defrost it works great.
Nov 23, 2014 | Refrigerators
Frigidaire fridge and freezer will only blow slightly warm air. Have both turned as cold as they will go. Not making any noise. Tried unplugging for a while but nothing changed. Any help would be...
Did this happen all of a sudden? or did the fridge slowly get warmer and then stop working after a week or more? i'm suspecting a comp issue, or a leak atm. leak if it slowly stopped, and comp start device most likely if it was all of a sudden. the tstat is working because the fan is on.
Aug 04, 2013 | Refrigerators
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Jun 06, 2010 | Refrigerators
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
Amana BR18 Doesn't get cold
Mine is doing the same thing
Jul 05, 2009 | Amana Freezers
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
