Question about Ecoquest Flair Air Purifier
THE WET DOG SMELL
When i TURN MY FLAIR PURIFER HAS A SMELL LIKE A WET DOG
  • 520 Answers
Try soaking the grid plate in ammonia
Posted on Jun 23, 2009
That is the smell that produce the ozone plates, that is normal,in all the devices purifiers that works with ozone plates, do not worry about that , that is crispy pure air.
a user.
Posted on Aug 10, 2009
2 Suggested Answers
Dutch7773
  • 31 Answers
SOURCE: WET DOG
Hi Teresa,
that is certainly not the smell the machine should produce :)
The smells, other then fresh air, might be 'trapped' in the filter. So washing the filter (top rack of the dishwasher works for the metal mesh filters) might do the trick.
Another trick you can try is to put the purifier on the floor, turn it on high mode (away mode) and put a box over it. Let it run for an hour or two and the smells should be gone.
Make sure you have fairly new plates, to make the machine more effective.
Dutch
Posted on Mar 05, 2009
I have a Flair air puifier but no ozone smell. I replaced the high voltage transformer( it was a 3500 watt instead of a 5000 watt transformer) The red light now flickers but no ozone smell . It has ne
Your ozone generator may have gone bad. It's the small black rectangular looking apparatus located near the bottom of the unit. It usually has a zip tie holding it to the circuit board. You will have to take the Flair out of it's case to see it. Make sure it's unplugged and remove the bolt from the bottom of the unit. You can then slide the framework out of the casing. It's also possible that it's time to replace your Ceramic Ozone Plates. They have a life expectancy of 2 to 4 years. The Flair has two of them that slide into slots in the rear of the unit. You can see them when you remove the washable filter. All items can be purchased on Ebay. DM
Apr 28, 2012 | Ecoquest Flair Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
I have the Flair Air Purifier. Everything except the light seems to be working. When i push the button, the fan jumps into high mode for a couple of hours as it is supposed to, but I don't notice any...
if you pull the unit out of the black box ( one screw on bottom) and then turn the unit up side down, their is a glass fuse in it. See if it is blown, their is also a fuse just for the ozone part it is marked F21 on the same board, it is soldered in the board, it is a black round fuse marked 400ma 250v on some models
Aug 21, 2010 | Ecoquest Flair Air Purifier
Can feel motor run, but fan doesn't turn and very little ozone smell-have new plate
same deal with mine. Im gonna open er up n give a look c. Im thinkin the fan motor is running but not enough 2 turn the blades. Im fixin 2 google fan motors now as a matter of fact.
Jun 09, 2010 | Ecoquest Flair Air Purifier
No ozone smell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 19, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
I loaned my son my Flair, and when I got it back it no longer makes the air smell "ionized", and the sanitizer button does not seem to work either...
ask the person who sold it to you if you do not know or cannot contact them please e-mail me at jdlorentz@omnilec.com
Oct 01, 2009 | Ecoquest Flair Air Purifier
WET DOG
Hi Teresa,
Dutch
Jan 11, 2009 | Ecoquest Flair Air Purifier
No smell
clean plates and blow out guts with compressed air. clean plates with mix of water and amonia!
Sep 28, 2008 | Ecoquest Flair Air Purifier
New house off gassing
You need to be careful of the saturation. It is an electrical apliance and can be a fire hazard if the fumes are too great. But from my experience with my Flair Classic it will diminish the fumes and smell, but will not completely eliminate it. The paint will have to cure. The unit does work wonders on smoke and musty smells though.
Aug 21, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
907 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
