Question about Labtec 961307-0914 Webcam
Howto install webcam - Labtec 961307-0914 Webcam
ErrorcodeE0601009
Remove software and re-install software could be a bug or software not installed completly
Jan 05, 2014 | Computers & Internet
No driver for a Yodata webcam
try with this to find your webcam driver http://www.test-cam.com/howto/Find-webcam-drivers.html
Aug 08, 2013 | Computers & Internet
How to install webcam?
Their is no way to " install" a webcam, but you can easily buy one here!
I recommend this one
Or if your on a small budget, you can buy this one for about 5 dollars.
As to install it, just refer to this guide:
http://cowboyfrank.net/webcams/HowTo.htm
Hope this helped!
Be Sure To Rate macapplezoo 100% OR Whatever You Think I Deserve!
Jun 02, 2011 | Acer TravelMate 529ATX Notebook
How do i talk to someone using my webcam i have never used one before
Hi,you will get a well detailed description of how to set up your webcam for talking at this link:http://cowboyfrank.net/webcams/HowTo.htm.
Thanks and good luck
Apr 16, 2010 | ASUS K50IJ-C1 Notebook
Webcam won't start in messenger
- try this if it is msn messenger
http://en.kioskea.net/faq/1953-how-to-configure-your-webcam-on-msn-messenger#launch-the-configuration-wizard
- also this one
Mar 29, 2010 | Computers & Internet
ASUS Webcam failure
Go to web site below, for the answer.
http://wiki.eeeuser.com/howto:controlcamera
finally, the step that fixed it was...
I went into control panel...
Install/Remove programs...
checked the "Show updates" checkbox...
selected "USB PC Camera device driver"...
and in the repair/remove dialog, selected "uninstall".
After the re-boot, webcam works beautifully again!
Mar 13, 2010 | ASUS Eee 4G Notebook
Webcam?
If you download the twain driver, your computer can manage the camera as any other optical input device, therefore , in that way you may use it as a webcamers.
However this camera had not been built to be a webcam and will not be recognised by messengers and similar software.
Better getting a cheap webcam instead.
Camera Twain Driver 6.8.0 Driver ...
Feb 03, 2009 | Canon PowerShot SX100 IS Digital Camera
Vista software download
http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exe
Sergio
Todo: Check USB port
Howto:
061027085005_16154.png Refit the USB cable into the port.
061027085005_16154.png Plug the webcam into another USB port.
061027085005_16154.png Use an external powered USB-Hub. Some USB ports on computers do not have enough power to feed USB devices (this mostly occurs with laptops).
061027085005_16154.png Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in
WindowsXP
061027085005_16154.png Click Start -> Control Panel -> System
061027085005_16154.png Click the tab Hardware and then click on Device manager
061027085005_16154.png Click at the bottom of the tree on the + sign before Universal Serial Bus controllers
061027085005_16154.png Select the first entry, right mouse click and click on Update driver...
061027085005_16154.png Follow the steps to update the USB driver
Windows2000
061027085005_16154.png Click Start -> Settings -> Control Panel -> System
061027085005_16154.png At the bottom of the tree click on the + sign before Universal Serial Bus controllers
061027085005_16154.png Click on General USB Hub, right mouse click and click on Properties
061027085005_16154.png Click on the tab Driver and click on the button Update Driver.
Todo: (re)install the latest driver
HowTo:
061027085005_16154.png Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
061027085005_16154.png Cleanup the computer with for instance CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
061027085005_16154.png Download and install the latest driver.
Apr 12, 2008 | Philips SPC700NC Webcam
Labtec 961307-0914 Webcam Logo
21 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
