Question about Lasko Ceramic Heater
I have a Lasko ceramic heater that keeps shutting down & when it does all the lights blink and 88 blinks where it shows the temperature. It's there something wrong? What should I do?
  • 10 Answers
SOURCE: lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Posted on Oct 16, 2009
SOURCE: Blinking lights. Shuts off.
Hello, Mne was also shutting down. Turns out that is was clogged with dust, therefore overheating and turning it self off. If you're handy, you may want to open the heater and dust it off with a can of compressed air.
Worked for me.
Posted on Nov 20, 2008
SOURCE: Have a lasko ceramic element heater
just wanted to say that I am having the same problem.  I turn it on and it stops working.  When I push the power, it only lights up for a second and beeps and then goes off.  Is there a solution to this yet? I think the company owes us an explanation.  I have already tried to plug it in to different outlets and still get the same results.
Posted on Feb 07, 2009
  • 35 Answers
SOURCE: I lost my owners manual & would like to know
Follow this link:
http://www.laskoproducts.com/heaters/heaters.html
and put in your model of heater. Once on your models page, the link to the manual is near the bottom of the page, a red link.
Posted on Mar 15, 2011
  • 12 Answers
SOURCE: how do i prevent my lasko heater to keep raising the temperature? i can't seem to set it to stay on one!
If its a central heating unit you should make sure the batteries in the thermostat are good and the fan switch is on auto. then you can open the cover to the heater and tap on the relay. that will usually shut it off if its just sticking. It could be a black box by itself or a box on the circuit board depending on the model
Posted on Nov 29, 2012
Lasko heater blinks 88 no heat
What type of Lasko heater do you have?
Nov 12, 2017 | Televison & Video
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
When i change the temperature to make it hotter, the screen blinks then goes back to being 30 degrees colder. Is my heater ignoring my request because it never reaches the temperature i want it to. it...
First you have to understand in thermostat there are Fahrenheit & Centigrade degree. If Centigrade between 16 to 30 and if it is Fahrenheit 60 to 86.
If you press the symbol ther> and > (or) ther- and ther+ at a time degree will change.
Now you set your temp +10 degree from your room temp and also keep "heat" mode.
Dec 14, 2010 | Heating & Cooling
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Model 5800
In page three in the manual it shows you how to set your temperature settings.eb6548e.jpg
Oct 30, 2008 | Lasko Ceramic Heater
Worked for me.
Oct 02, 2008 | Lasko 5132 Ceramic Compact Heater
Lasko  Ceramic Heater Logo
83 people viewed this question
Top Lasko Heating & Cooling Experts
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
