Question about Toshiba REGZA 32WLG66 32 in. Television
My tv keeps showing a menu headed with main, then it scrolls without me doing anything, through the options on this screen
The remote control is unable to stop the scrolling
2 Suggested Answers
SOURCE: toshiba 32av615db tv - keeps scrolling channels
On the back of the TV, where the main board is (the one with many AV inputs to it) there are several cables going into it.
Find the one that leads to the buttons on the TV - it won't be too hard to trace - and after turning on the TV disconnect that cable.
Or, if the cables for the buttons and the front LED and IR sensor are separate (sometimes they are) you disconnect the one for the buttons and then turn the TV on with the remote.
Either way, see if the problem persists with the buttons panel disconnected.
if it does then the problem is in the main board and likely you'll want it replaced. The way they make them these days it's really cheaper to replace the whole thing than to look for a problem among components the largest of which is about a millimeter long.
if the problem is in the button/cable connector...you'll probably find it easy. Often it's because that same cable has been trapped between the front and back covers and broken or shorted by the friction and pressure.
Hope this helps....would appreciate a review on Google if it does!
bobby
www.coppelltvrepair.com
Posted on Oct 09, 2012
I have a Sharp Lc-32LE451U. Why does the Input menu keep showing up without me hitting it on the remote? And sometimes changing to "component" on its own?
sounds like main system control IC fault. Contact any service technician. But before that, do a reset to this set and check.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 06, 2014 | Televison & Video
I have a 20 inch tv from rca with no remote. My screen says fpa lock is on. Tv will not come on. What do i doi
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
To get more details, http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Televison & Video
LG 47LG50 Program Menu displays on its own without remote control or manual inputs.
Thats the IR board. You can get the IR board along with the button assembly at the following link for your model its 15.00 just scroll down the page. It also may be the main board that has the issue if it is you can also get the main board there also its 84.00
http://tvrepairworld.com/lg__zenith_lcd__plasma_power_supply_boards
Dec 16, 2012 | LG Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
Sharp tv keeps changing the source channel on its own
you may fave a faulty switch in the key controller, may best advice is replace it
Part numbers:
KC792
XC792WJ
Fred
Jun 18, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
Menu Scrolls Uncontrollably
The most common cause of the problem is a stuck/shorted button either on the television or on the remote. The worst case scenario is a faulty key control board. Remove the remote control battery or put it away from the television. Press the menu button on the television and check if the menu scrolls by itself. If yes, the DOWN button is stuck or shorted. You can actually hear or feel it click when pressed if it is not stuck.
Open the back of the television to gain access to the key control board. You can either repair/replace the faulty button or replace the key control board. Remove the screw holding it to the television casing. Disconnect the old board and install the new one.
Replace the remote control if the buttons on the television control are working properly.
Jan 16, 2010 | Haier HP42BB 42 in. Plasma TV
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Menu scrolling and can't stop it
Your set is in DEMO mode......consult owners manual....
Usually in menu pages.........Oh, switch back to English...
select Lingua to change.........T.
Jan 12, 2008 | JVC AV-27432 27" TV
Scrolling through menu on it's own
I'm having the same exact problem. does anyone have suggestions? mine is going through the menu and other video ports without cause. mine is also about 2 years old and started doing it today. its always been in a dust free clean enviorment. please please please help.
Jan 15, 2007 | Toshiba 35A44 35" TV
Toshiba REGZA 32WLG66 32 in. Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
