Question about Garden
Scorpion y650 build a kit - Garden
How do some scorpions glow when light shines on it?
Do scorpions glow? Yes. That's an easy question to answer. It's a bit more difficult to pin down what exactly causes them to glow. In fact, scientists are still working on finding a firm answer to that question.
What scientists do know is that something in the scorpions' exoskeletons cause them to glow. Scorpions, along with other arthropods and insects, have an outer layer called a "cuticle." Unlike the cuticles on your fingers, which are made of hard or dead skin, the cuticle on a scorpion is a part of its exoskeleton. This cuticle has a thin section called the "hyaline layer." The hyaline layer is what reacts to ultraviolet (UV) light, such as black light or moonlight, and causes the scorpion's body to glow.
The hyaline layer is really strong and truly stands up to the tests of time. In fact, scientists have found that even fossilized scorpions glow under UV light. Additionally, when scientists preserve scorpion specimens in liquid-filled jars, the hyaline layer can make the liquid glow! Crazy, right?
While observing scorpions, scientists have noticed that the creatures don't glow immediately after molting. Rather, the cuticles have to harden completely before they shine blue-green in the starlight. But scientists still don't know if the glowing material comes from a chemical reaction in the hardening process, or if the scorpions actually secrete the glowing substance.
May 14, 2017 | Cars & Trucks
How to lenovo y650 reset bios password
If you forgot the password then you'll have to reset it. See if there are any password reset tools from Lenovo to help you through this problem. If not, then pull the CMOS battery of the unit to reset the unit back to the factory settings. This should clear the password and may also reset the time and date too.
The battery is usually found through a little access panel somewhere on the unit's underside. You'll need to research this on your own but I suspect removing the panels underneath the unit will expose it. The battery looks like a CR2032 battery. Sometimes it is covered in black plastic and has black and red wires coming out of it with a tiny connector on the end.
Aug 15, 2014 | Lenovo Y650 4185-55U PC Notebook
I have a Lenovo Y650 4185-55U ptop and need instructions on how to open it so I can replace the dvd drive.
Flip pc over. There will be one screw not part of a plate. About an inch in front of the battery and about 4 inches from where you would put in a DVD. Only one screw holds the DVD in. Unscrew it and gently slide the optical drive out. If the optical drive does not move with some gentle prying with finger nails or a plastic tool, you did not loosen the correct screw.
Mar 26, 2014 | Lenovo IdeaPad Y650 418534U Laptop Charger...
Hi all I need to replace my network adapter card for lenova y650 laptop. Should i get an upgraded or replace with original
Welcome to Fixya
As a lenovo employee, i would suggest that let our repair department replace the network adapter for you. If the computer is still under warranty call our 24/7 tech support and we will glad to schedule a repair for this unit. Our phone is 18774536686 then press option 2.
Thank you for using Fixya!
Jan 23, 2011 | Lenovo Y650 4185-55U PC Notebook
My y650 ideapad turns on, tries to load Microsoft
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems.
support.microsoft.com/kb/306084 -
Apr 10, 2010 | Lenovo Y650 4185-55U PC Notebook
How do you release and change saw blade on scorpion saw
Grip blade. Push black button on side. Rotate blade through 90 degrees.
Oct 11, 2009 | Scorpion Toys
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
