Question about Refrigerators
My Refrigerator i s not cooling properly - Refrigerators
  • castro1 Apr 01, 2009
    FREEZER IS WORKING BUT THE TOP PART IS NOT COOLING
    ITS A DEFY C370 FRIDGE
  • cwumbs Apr 09, 2009
    I have an integrated fridge, electrolux, it was bought 2nd hand quite cheaply, but i've noticed it doesn't 'run' unless the dial (0-5) is set at 5 and then only intermittently.
    Food certainly doesn't seem cold, just slightly cool.
    I have also noticed a crack in the back of the interior casing, would this cause the fridge to stop refridgerating?
    Any ideas anyone, before we buy a new one?
    Thanks
    Cwumbs
    Scholar:
  • 67 Answers
Check the back of the fridge and see if the coil is clean. If it is dirty then give it a wipe down. If the coil is clean then turn off the for two minutes and turn it back on listen for the compressor to start. If the compressor starts it is going to be a gas issue or electrical.
If the compressor does not start then you are up for a new compressor or something electrical. With out knowing anything more than what have you wrote, I would say to check these things and call a refrigeration tech.
Other than that I can offer support if you like
Posted on Jan 11, 2009
Can get my fridge freezer off the vacation button
This is list of refrigerator problems,which is normally faced in refrigerator.
You can go through the details,by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Dec 22, 2012 | Refrigerators
Refrigerator not cooling. Freezer cold
Check the help link mentioned below:---Refrigerator is not cooling properly?
These will help.
Thanks.
Oct 04, 2012 | Dometic NDR 1062 Refrigerator
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
This willhelp.
Thanks.
Feb 10, 2012 | Maytag MBR2256KES / MBL2256KES
Gss22sgpass
Refrigerator warm,indicated no cooling problem.Click the link below to troubleshoot the issue.Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | GE Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
Fridge area not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hl
Jun 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Jenn-Air JCB2389GRS Fridge not cooling properly
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
583 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
