Question about Microsoft Word 2003 for PC
Hi running word 2003 have an auto fill in the date feature installed on a fax template how do I disable it. if I open up previous documents composed the present date populates yet the document was composed prior to todays date.
  • 289 Answers
This is caused by the document using a "field" and not an actual date. Press <ALT+F9> to see the date's field code. You will probably see: { DATE } or { DATE @ "M/d/yyyy" } (NOTE: The M/d/yyyy formatting may be different for you; since this is personal choice). You can manually delete the field and type in your date. To automate this, open the TEMPLATE (*.DOT) and change the field by using: Insert > Field... and selecting "CreateDate" from the Field names list. Also - set your desired format too and then click <OK>. Save the change to your template and it will use the date you create the fax and keep that date if the fax is saved as a document and reopened in the future.
Posted on Apr 21, 2009
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied...
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Dec 29, 2010 | Dymo LabelWriter 330 Thermal Printer
Virtual Printer Deleted after Windows Update....I Can't printing MDI from internet page ((( Help please ... Office 2003 SP2 Had Before This MDI Printer very Good
First step, ( May be your print spooler service is not running )
1. See if you are able to find no printers at all in "printer and faxes" on control panel.
2. If not - go to start->run -> type "services.msc" and hit enter. Locate "Print spooler" service. See if that service is running on not. You might see "Started" in front of that means working. You can right click "print spooler" and restart once and check "printer and faxes" on control panel. If not follow step 2.
step 2:
You can reinstall the MDI printer by doing custom installation of Microsoft Office 2003. To do that follow below instructions
1. Go to Start->Run->Type "appwiz.cpl" and hit enter. This will open up Add Remove program wizard for you.
2. Now locate MS Office installation and click on "Change"
3. Check mark "add or remove feature" and click "next".
4. On the botton of the installation window check mark "choose advanced customization of application" and click "next"
5. Under "Microsoft office" expand "+" sign of "office tools"
6. Locate the object "Microsoft office document imaging". Click the icon and select "not available" and click on "update". This will uninstall the MDI drive.
7. Repeat the steps from point 2 and locate the object "Microsoft office document imaging" click the icon and select "run from my computer" and click on update.
Above steps will re-install the MDI drivers and you can find the virtual printer going to printer and faxes on control panel.
txsup
Mar 29, 2010 | Microsoft Windows Server 2003 Enterprise...
"this modification is not allowed because the document is locked"
Rename all instances your document template files (Normal.dotm or Normal.dot) to prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened, rename your global template (Normal.dotm or Normal.dot). Renaming the template lets you quickly determine whether the global template is causing the issue.
When you rename the Normal.dotm template in Word 2007 or the Normal.dot template in Word 2003 and in earlier versions of Word, you reset several options to the default settings. These include custom styles, custom toolbars, macros, and AutoText entries.
Jul 12, 2009 | Microsoft Office Professional 2007 Full...
MS word not responding
Rename all instances of your document template files (Normal.dotm or Normal.dot) This will prevent formatting changes, AutoText entries, and macros that are stored in the global template (Normalm.dot or Normal.dot) from affecting the behavior of Word and documents that are opened.
Dec 15, 2008 | Microsoft Office Outlook 2003 for PC
Windows word 2003 Autotext not working.
Not sure what problem you are having with AutoText. One problem could be that you do not have the show autocomplete suggestions checked off. To do this go to Insert, AutoText, then AutoText, and look for the tab AutoText. Make sure the check box marked show autocomplete suggestions is checked off. There can be other parts of the Auto text that is not working for you and you may be able to look around in the other tabs to find the part that is not activated. If you give me more information I might be able to answer a more specific question.
Nov 27, 2008 | Microsoft Office 2003 Basic Edition...
Keyboard locked out for microsoft word 2003
It's not the keyboard. If it was, it wouldn't work in anything.
It's possible that the "normal.dot" template is protected. This will result in any document created using that template also being protected. Try going into File -> New and creating something specific, for example a menu, that uses a different template. If suddenly you can use the keyboard, then you've found the problem.
Under those circumstances, use the Windows Search tool to find the file "normal.dot" and delete it. When you run Word again it will create a new, unprotected document template called "normal.dot" and Word should function correctly from then on.
May 23, 2008 | Acer TravelMate 354TE Notebook
Faxing redial problem
Open the left fax display cover. Find and hold down the "Alternate Display" key. While holding it down, press the "Stop/Clear" key. The transmission will be cancelled.
Automatic re-dialing is preformed by this machine unless you are in the direct transmission mode.
To set the default to direct transmission:
Press the "System/Menu" key,arrow down to "Fax Default".
Press the "Enter" key. Arrow down to "TX/Default".
Press the "Enter" key. Arrow down to "Direct Feed Transmission" and press the "Enter" key.
When you are finished, press "Reset".
Mar 30, 2008 | Kyocera Mita KM-2050 Printer
Word 2003 'save as' problem
It is possible that some .dll files in the OS are corrupted. Try running scandisk.
S. Mohan
Oct 22, 2007 | Canon DR-2580C Path-Through Scanner
Microsoft Word 2003 for PC Logo
154 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
