Question about Panasonic PT-47WX49 47" Rear Projection Television
PT-47WX49E Doesn't work
I have a 5 years old Panasonic PT-47WX49E. It turns itself off immediately within 2-3 seconds of turning it on then it will not turn on unless you unplug the power cord and then try it again. It will do the same thing again. It seems like the TV's circuity is detecting something wrong and turns itself off. Does anyone know what the problem is or where the problem could be? I have a electronic background but never fixed any tv. Also, if anyone have the schematic for this TV I would appreciated if someone could send it to me.
Scotty5 I have the exact same problem. If you come up with a solution, please let me know. Mine just started having this problem this morning. thanks, tripwire@techie.com
Posted on Aug 06, 2007
I was given a 42 in panasonic because it had this problem. I took it home and plugged it in and pushed the power on button. before it could come completely on I pushed the power off button. I did this 3 times and then turned it on and TV worked fine. This made my friend sick since he just bought a new one. I offered it back but he said keep it. :)
Posted on Jun 20, 2007
    President:
  • 3,130 Answers
This is for sure a safety shutdown circuit that is shutting down this TV set. It is a hard call to pinpoint a problem such as this without first doing some troubleshooting on the TV set. You could have a short in the sweep power supply, the horizontal output transistor could be bad, therefore then the flyback is probably bad, or the vertical IC could be bad, there could be a regulator problem in the main power supply that could be bad, and also the convergence IC's can cause this problem. Almost any circuit inside this TV set can be detected and staop the set from starting up. Good Luck
Posted on Jun 07, 2007
Panasonic PT-47WX49E blue convergence problem.
if convergence does not adjust in menu mode could be a defective convergenceic or fuse
Nov 11, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt53wx42f
This sounds like a main power board issue. After you unplug it, it will work? Are you planning on trying to service it or having it serviced?
Thanks,
Lee
Jul 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
TV Won't Turn On
the lamp is bad. panasonic has a 5 year part warranty on the lamp and 2 years labor
Oct 18, 2008 | Panasonic PT-61LCZ70 Television
Panasonic PT-47wx49e
The repair tech is wanting to take alot of your money, you can get the entire deflection baord which has the flyback on it remanufactured for about half of what he wanys to change the flyback. Heres alink leave them a email with your model number they will send you a quote to have your deflection D board rebuilt which carrys a full warranty. heres the link.
http://servicemanuals.vstore.ca/
Oct 12, 2008 | Televison & Video
Panasonic PT-47wx49E
does the led indicator blink? If so how many times does it blink?
Sep 04, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
