Cerwin vega ve 12 i need a crossover for a ve 12 does anyone know where to buy one without buying a whole new speaker i bought 2 ve12"s last year noticed at higher volume one speaker the highs would cut out then would come back in at lower volumes after a few min a few months ago the tweeter and mid just stopped all together my other ve 12 i have had no issue with what so ever at any level of volume i love these speakers would really love to have the other one playing again please any help would be greatly appreciated
    New Friend:
  • 19 Answers
Go onto the internet to see if any one has crossovers for them, Evan check out ebay.
Posted on Dec 03, 2012
Replacement woofers for Cerwin Vega HED 3way 12. Can I use woofers from the LS Series?
Absolutely, as long as they are the same impedance.
If you are unsure, use an ohmmeter to check the static impedance of the replacement speakers, and be sure that it is with in 2-3 ohms of the listed impedance of the speakers you are replacing (otherwise, your crossover points will be wrong).
May 14, 2015 | Cerwin Vega Audio Players & Recorders
Multi channel Av reciever model STR-DH540
I went with Cerwin Vega for my speakers and they have been great. You can find them at Best Buy I believe or even order over Amazon.com (shipping is always high). Be careful buying over eBay unless they are like new or new--you don't know how they've been used or abused in that case. I have 4 smaller bookshelf speakers for the surround and back surround, an LW12 subwoofer, and some 10" Cerwin Vega L9 units for the front. I also bought a nice CV center channel speaker--went a big bigger and better on that unit as it plays the voices on 5.1 and 7.1 surround.
Jan 25, 2015 | Audio Players & Recorders
I just purchased 2 12"
bigger is always better, use the 12 if you have it. higher gauge = thinner / not better.
Mar 08, 2011 | Cerwin Vega E-312 Speaker
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
Cerwin Vega D9-E Speakers. Bad crossovers...I think. Fixable?
Crossovers are made with wire coils, electrolytic capacitors and resistors.
Capacitors may get leaky or blown with time and heavy use, and are quite easy to find, just be sure to use the same polarity, capacity and voltage rating and to respect the polarity if it's a polarized capacitor.
There may also be a burnt out resistor or a coil. Resistors can be obtained and replaced (same resistance and wattage) and wire coils can be rewound (same amount of wire of the same wire gauge).
Another possibility is a partially damaged wire on the speaker itself. This is the braided curl wire that goes from the speaker membrane to the cable connection lugs on the speaker armature, and it may be damaged at the membrane side or the lug side.
It usually happens from what you call "overcooking".
To repair this it will require some soldering skills, but it's a bit hard to solder that type of wire, as it tends to oxydize and is difficult to clean prior to soldering, it may be difficult to access it, depending on the speaker structure(an alternative to this is to replace the speaker itself).
There may be some physical damage to the membranes if the sound is present but is of a bad quality (a slightly damaged membrane may be repaired using some rubber glue, but it will never return the speaker to the original condition).
These are just some suggestions, hope they can help you get closer to a solution.
regards
3rq8 (triarcuate)
Jul 23, 2009 | Cerwin Vega CLS-12 Main / Stereo Speaker
Need air volume spec for box , for a vega 12 inch stroker
If you building the box, make it as big as possible still being able to fit in the vehicle. If your buying a box do the same. Buy it as big as possible and still be able to fit.
Jun 29, 2009 | Cerwin Vega Stroker Pro 12 Car Speaker
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Cerwin Vega V-35 Horns Drivers Model TMH-1
first you need a multimeter set to OHM , check on the back of the horn , remove the leads and do some reading , it should read 4 , 8 , 16 ohms depending of the brand , if you get no reading its means that need to be replaced , some horns you can detach the back (magnet w/the coil ) so you can replace it without buying the whole unit . good luck
Apr 19, 2008 | Cerwin Vega LS-15 Speaker
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Open Questions:
154 people viewed this question
 Grubhead
Grubhead
