Question about Apple iPhone 3G
My iphone is stuck amd will not go to home page
Iphone stuck when unlocking slide then go directly to phone mode and will not let me go to home page by pressing home key can i rest it
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 87 Answers
Cause it is in restore mode. If you have a 2g use this tutorial to unlock your phone with the 3.0 update.
If you have a 3g use this one currently you can not unlock a 3g under the 3.0 firmware.
Posted on Jul 01, 2009
My phone is locked up and gets a box around whatever I touch on my home screen (time, date, slide to open, etc.)
You are in an accessibility mode called voice over. Using Siri voice command: open accessibility settings.
To navigate in voiceover mode, Three fingers will get you to scroll, Tapping once on an object Will select it, and double tapping will execute a change. See photos below
Aug 15, 2015 | Apple iPhone 5
Slide to unlock is stuck
Hold down the power button and home button together until the phone restarts and the apple logo appears. Once rebooted, slide to unlock should work correctly.
Feb 12, 2013 | Apple iPhone Smartphone
My iphone screen is stuck. i tried to reset it so many times, by holding home & power buttons until apple logo appears. but still slider hangs. I can't turn the power off.
What happened before this? You mean you cannot enter the homescreen because you cannot slide to unlock? How about restoring it in iTunes? If you have a back up, just restore and then restore from back up.
Enter DFU mode first so iTunes will detect your iPhone is in recovery mode.
http://www.fixya.com/support/r8568726-enter_dfu_mode_iphone_ipod_touch_ipad
Mar 16, 2011 | Apple iPhone Smartphone
This picture comes up on the front of my phone of a chord and a pic of the itunes app. I can't get to the main phone to use it
sounds like its stuck in DFU Mode
http://www.iphonealley.com/tips/save-your-iphone-with-recovery-mode
If iTunes doesn’t see your iPhone’s cry for help, you may need to invoke recovery mode. Although it’s an extremely helpful mode, how to get there isn’t very apparent. Read on for the how-to!
As arcane as “recovery mode” sounds, it’s actually very simple:
Disconnect your iPhone and turn it off by holding the “Sleep/Wake” button for about five seconds and then sliding the red slider. If your iPhone is already off, there’s no need to turn it on and then off again. Once it’s off, press and hold the “Home” button and plug your iPhone into a Mac or PC with iTunes installed. Keep holding the “Home” button until you see a dock cable pointing to the iTunes icon. iPhones running older software will display a yellow triangle and text which says “Please Connect to iTunes”. Once you see this image, you can release the Home button.
Open iTunes (if it’s not already open) and you will be told that “iTunes has detected an iPhone in recovery mode.” Click “OK” and you will be taken to the iPhone pane. Click “Restore” and you’re done, it’s that easy! Depending on the extent of your iPhone’s ills, it may take some time to do a full restore. Once you’re done, you should again have a perfectly working iPhone.
If this doesn’t solve your problem, you may need to restore using DFU (Direct Firmware Upgrade) mode. To enter this mode, plug in your iPhone and turn it off. Hold down the “Home” and “Sleep/Wake” buttons for about twelve seconds. You’ll briefly see the silver Apple logo and then your phone will appear to turn back off. Release the “Sleep/Wake” button but continue to hold the “Home” button until you see a message in iTunes stating that it has detected an iPhone in recovery mode. Choose “Restore” and you should be fixed right up!
If this doesn’t fix your problem, your iPhone may require a visit to the Genius Bar
Aug 28, 2010 | Apple iPhone 3G
The phone is stuck in the turning off the mode.
hold down the power and home button at the same time until the screen goes black then keep holding. wait until you see the apple logo, then you will be good.
Apr 05, 2010 | Apple iPhone Smartphone
My phone wont do anything!!!!
To getout from stuck or in DFU mode try this.......To Normal Mode Just Keep Press Home+Power For 5 sec Then
Release The Home Button And Keep Press Power Button for 50 Sec U Phone Will Powering On
Regards..
If your iphone is still in stuck after trying the above instruction you must jailbreak it and unlock.then enjoy using your iphone.If you want some help heres my YM:exel_bernardo@yahoo.com
Jul 22, 2009 | Apple iPhone 3G
IPhone won't do anything!
Before you connect your iPhone or iTouch to iTunes.
Try and put the device into DFU Mode.
Plug your USB cord into your Device and Not into your computer.
Turn the Phone all the way off by holding the power button until the Red Bar appears and Slide it off..
Hold the "Home" Button Down for 5 seconds.
Then Push and Hold the "Power" Button while still holding the "Home" button and count to 7
Let go of the "Power" button while still holding the "Home" Button and Hold the Home button for approx 26 seconds.
The screen may or may not go blank with lines. No Worries!! now plug the USB into the computer with iTunes open. If the iphone is in DFU mode, iTunes will come up with a popup that says, "Itunes has detected an iPhone that is in recovery mode. Your must restore it"
Once this occurs, you can restore your device with any firmware by pressing "SHIFT" on your keyboard and "Clicking" Restore with your Mouse. Restore your device and let it mount to itunes.
If you are unlocking the device, I would suggest using "QuickPwn" you can get it HERE
You can download Apple iPhone Firmware HERE, when using quickpwn you will need to upgrade your firmware to 1,2_ 2.2_5G77...NOT 2.2.1
(TIP: Don't restore your iphone with custom firmware in iTunes. Restore with the original Firmware and Unlock or Jailbreak letting Quickpwn make the custom firmware....Also if you have a 3G do not ungrade in itunes to the 2.2.1 firmware, it changes the phone modem baseband and renders it "NOT" unlockable)
Feb 28, 2009 | Apple iPhone Smartphone
Iphone stuck on restore
this is what i have just found,Hold the home button down (on the front of your iPhone) and connect the device to your laptop/PC while iTunes is open. A message should pop up and say that youriPhone is in recovery mode and needs to be restored. Click on your device (in the iTunes windows) along the main toolbar, then go to the Summary tab.30 Jul 2014
How to Fix an iPhone Stuck In Recovery Mode ' Enigma Recovery
https://www.enigma-recovery.com/fix-iphone-stuck-recovery-mode/ Iphone stuck on restore Google Search
Oct 24, 2017 | Cell Phones
Iphone is disabled connect to itunes and when i connect to itunes it says "cannot connect since it is locked with a passcode. unlock the phone. what can i do?
To get iphone to connect to itunes disconnect it from USB cord, press on/off button until you see slide to turn off, slide to turn iphone off. After iphone is off press and hold home button and reconnect to USB cord (do not release home button) continue holding button until you see itunes has detected an iphone in recovery mode then release home button. Proceed with restore.
Aug 10, 2008 | Apple iPhone Smartphone
My iPhone is stuck at apple/loading page
U tried the safe mode? Get there by holding the sleep and home buttons down (same as rebooting) then once the phone is off, release the sleep button, but keep the home button down. iTune should then notify you that the iphone is connected in safe mode. Unfortunately I had the same problem ended up restoring the phone.
Apr 23, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
255 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
