Question about Car Audio & Video
Hello, My jvc kd-r716 car stereo has faulted. I can not turn on. I have checked power source and all is okay. If I push eject or display the unit responds to those 2 functions brieflly then turns off. The problem started when I was using the ipod function, (which I have used many many times). I tried to change a song and the buttons were unresponsive, I could not do anything, adjust track, volume, power off etc. I had to turn the car off. When I turned the car back on I have my current issue. Can you please help?
  • burhanuddine issoufaly
    burhanuddine issoufaly Apr 20, 2016
    hello, I'm facing exactly same problem. did you find an issue?
  • Rob Holding
    Rob Holding Jul 04, 2016
    Same thing happened with mine but it occurred when fast forwarding a Bluetooth track.
    Master:
  • 426 Answers
You can reset the radio, there is usually a small reset button that you need a small pin to push or you could disconnect the battery for five mins and reconnect. See if that helps.
Posted on Jul 04, 2016
  • Rob Holding
    Rob Holding Jul 05, 2016
    No, we've tried that but it's no good. It works fine with the remote you just can't use the head.
  • Steven's Electronics
    Steven's Electronics Jul 05, 2016
    The head unit itself is bad then and is best to be replaced
3 Suggested Answers
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
How do I connect a JVC CD player KD-R716 to 2010 Hyundai getz?
you need to rewire if you have an old unitinstalled. follow wiring diagram of your jvc. cut old wires and connect it to your new jvc. adapt your new wiring by comparing
Feb 25, 2011 | JVC AM FM CD DET FACE CAR STEREO
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
Jun 10, 2009 | JVC KD-G200 CD Player
My JVC KD-S25 will only turn on when I press the eject button, and then it shuts off in 5 seconds.
I just bought this stereo and installed it the other day. I had the same issue. Hook the Yellow power wire and the red accessory power wire to the same power source. That solved my problem.
Oct 11, 2008 | JVC Car Audio & Video
Car Audio & Video Logo
272 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
