Question about E-Machines eMachines Desktop PC
E machines 442 wont boot up it keeps looping start but just black screen
  • E-Machines Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in.
Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit.
If you can get your computer stable enough
scroll to bottom toolbar bottom of screen right click select task manager
applications you will see whats running if you see anything you dont need running select end now
also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs
not having enough computer ram can cause memory dumps
If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible.
You might have a virus or malware.
Download at least one of these of course it will depend on your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Hope this helps.
Posted on Dec 01, 2012
Toshiba satelite a105 keeps looping in the boot menu
No blue screen or number, it use to work find, this problem start last week
Jul 05, 2017 | Toshiba Satellite A105-S1712 Notebook
Ifit console will not load keeps running in a loop?
try to RUN the software calibration, see your instr. manual how to enter and proceed for easy diagnose, troubleshooting, and fix it.
God bless you
Dec 11, 2012 | Nordic Track Incline Trainer X9i...
Windows wont boot past the first xp screen restarts again and again in a loop and pressing f8 doesnt work wont le
In that case, place your System disk in the DVD/CD drive after setting the BIOS to CD ROM first boot and boot the machine choosing repair system from the menu.
Hope this helps.
Dec 30, 2010 | MPC Computers ClientPro 365 PC Desktop
Wont boot,keeps asking 2 F1 then'start normally' screen then afta a while back to F1,
your system has dropped into a "boot loop".. The best way to fix this is to place your Windows install disk into the machine, then reboot. Go into the BIOS screen and change the boot sequence so the PC boots from the cd or dvd drive then save and exit (F10). once the system gets to the "press a key to boot from cd" option, press a key and let the installation system start up. This will detect an exisiting installation BUT, when it asks if you wish to repair using recovery manager, Press NO.. Then it will go to the setup screen and ask if you would like to fix the existing installation, press YES and setup will replace the damaged system files and re-write the MBR. Let setup finish and remove the disk at the end of the installation then reboot. All should now be well and your files should still be available too..
Dec 27, 2009 | Compaq Presario 5000 PC Desktop
XP won't boot up.screen shows safe mode
The operating system files got corrupted.You can try repair the windows using operating system cd.
Siju
Oct 26, 2009 | IBM ThinkPad T60 Notebook
I have a black screen that has come up that says Windows cannot start because following file is corrupt or missing: windowssystem32configsystem then says I can attempt to repair this file by starting...
If a Repair doesn't work, then your system is too corrupt to repair, you need to install a new copy of Windows.
You won't lose your files, but you'll have to reinstall all your old programs.
Oct 22, 2009 | ASUS Eee 4G Notebook
Ok,was starting and then shuting itself off,now it starts, all of the lights are on,but no boot and black screen. for a HP DV6000
most commonly this is called a bios loop, this is due to the fact of a currupted bios command or a damaged cpu. to eliminate bios you must disconnect battery and cmos battery usually located where memory is, cmos battery is a small cable attached to a metal disk. unattach hard drive and restart computer. after restart shut down computer and reattach battery. again start computer without hard drive. if bios screen does not appear and same sceneario occurs then your CPU is fried. If bios screen does appear and you reinstall hard drive and get same boot error then your boot sector of hard drive is gone.
Due to black screen at boot and boot loop I would say ypur cpu is gone.
Sep 27, 2009 | HP Computers & Internet
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
My sons dell e520 wont start . i get the windows starting screen then it switches to a black screen with the messag floppy diskette seek failure then the options f1 to continue or f2 to run the set up...
Have you tried to put a disk in the floppy drive when it starts up?
It probably had a disk in before last close down, and is looking for it now when you start up.
Please vote if this was helpfull :-)
Nov 29, 2008 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
