Question about Maytag Dryers
Reach dropped toothbrush?
Too cheap to buy lint lizard, need repairman, slid down maytag dryer vent slot slid under the spinner
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
  • 1314 Answers
SOURCE: DRYER WON'T HEAT.
ok facing the drier front open thee door and remove the bolts around the door panel there are four of them two on each side then grasp the front about 3 inches down on either side to disengage the side retain clips tilt the panel back toward you and lift it up to disengage the bottom clips remove the front panel and if you need to lift the top remove the screws on the hooks on either side at the top and take the hooks off then you can lift the top that should give you plenty of access to do what you need to do
Posted on Jan 20, 2008
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
Lumpy816
  • 246 Answers
SOURCE: maytag atlantis dryer exsess builup lint
What product have you purchased from this site? We are a collection of knowledgeable people who are not afilliated with any manufacture. While you have the OPTION of paying to work with someone live, if you leave your information posted for a day or two, one of us will generally get back to you with some FREE help.
Now on to your problem. While I don't know what model of maytag atlantis you have, these are the general guidelines for cleaning out under the lint screen area. The easiest approach is to buy a vaccume extension availible from appliance parts stores and some hardware stores. I have even seen a clean out kit for sale at bed, bath and beyond. Basically you fit the vaccume extension on to the end of you vaccume and feed it down to the area under the lint screen. To do a more efficent cleaning you would need to dis-assmble your dryer. If you can supply the model number located just inside the door, I could get you a step by step tear down to get to it from the inside.
Posted on Jul 05, 2008
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
canbruce75
  • 1776 Answers
SOURCE: Dryer vent filled with water. Large loads would not dry.
If the drying problem is caused by poor venting/air circulation, then things probably won't improve until that situation is remedied. Check out the link I am attaching. It contains dryer venting requirements. Hope this helped and I'm sorry for your trouble. Best wishes.
http://www.mediafire.com/?4yazrf2jz3d
Posted on Sep 07, 2009
Testimonial: "Good info. System working okay now. I put 12 feet of flex pipe and then 25 feet of foil. The a/c ductwork prevents getting in to replace from dryer"
Call the Maytag man because I dropped a toothbrush down dryer lint vent?
You can do this yourself.
What is the complete model number of your unit?
Dec 03, 2012 | Maytag Dryers
Remove dryer vent door?
What is the model number of the unit?
Dec 01, 2012 | Dryers
My frigidaire dryer start and a few seconds later an alarm sounds and E68 appears.
Remove your lint filter. Now remove the waffled plastic that covers the lint filter slot. Hint, its inside the dryer, and there's two screws holding it in. Be careful when you pull it out, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is either the temperature or moisture sensor, I bet. Don't drop the screws into the lint filter slot. If yours is like mine, you'll find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint (use soft toothbrush), and reinstall. While you have it opened up, stick your vacuum's crevice tool down inside the lint filter slot and clean up all the lint in there as best you can. Problem solved. I think the build up of lint was shorting the two contacts, and this was screwing up the electronics.
Sep 12, 2010 | Frigidaire AEQ6000ES Electric Dryer
How do I get to the heating element? It isn't heating as well as it used to and I think I need to replace the element.
Before you do that, here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
2) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners2_bing.gif can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
May 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
Maytag Neptune gas dryer MDG4000AWW not heating properly.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jul 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
Jun 01, 2009 | Maytag Dryers
Maytag dryer
Dear sloika,
I do not believe the problem lies within the dryer unit.
when the dryer unit fails to dry clothes in reasonable time 90% of the time it is the clogged air vent is the reason.
Dryer vent cleaning improves the safety and efficiency of your dryer installation. As dryer vents become filled with lint and other debris, drying time increases and can cause the dryer itself to overheat. This increases energy consumption since the dryer has to run longer to dry your clothes and can also cause fires in the dryer or the dryer duct. The Consumer Product Safety Commission reports dryer related home fires are on the increase.
  • First check your vent hose between the back of dryer and the air outlet on the wall. Vaccum clean the dirty hose and even into the dryer unit using flexable vaccum attachment. also try to vaccum clean airoutlet that goes into your wall as far reach into and much as possible. The dryer's lint filter and its path needs to be cleaned as well.
  • If all air flow path are cleaned it will improve 200% of your drying time.
There is also professional dryer vent cleaners in your area who can help solve the problem. just check your yellowpages..
Feb 16, 2008 | Dryers
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
