Hp c6180 all in one printer displays error 0x000000aa is there a fix for this
    Sergeant:
  • 241 Answers
The names of places on your computer may vary depending upon your version of Windows but you essentially have to do the following...
-Go to "Devices and Printers" right click the printer and select "Use Printer Offline"
-Stop the Print Spooler Service. The rough path for this is as follows:
Start>Control Panel>Administrative Tools>Computer Management>Services and Applications/Services
-Now double-click Print Spooler and click Stop
-Now click Start
-Now right click your printer again and select "Use printer offline" again
The error should now be history.
Posted on Dec 01, 2012
SOURCE: carriage jam error statement on hp photosmart c6180 printer
Carriage jam open door , clear carriage jam and press ok. How?
Posted on Dec 31, 2009
SOURCE: printer error code: 0x000000aa......
Hi. First you have to check "Use printer offline" for that particular printer then you have to stop the Print Spooler Service then start it again and only now you may configure the port configuration for that particular printer. After you do that uncheck "Use printer offline" and voila: it works. Good luck
Posted on Jan 29, 2010
SOURCE: error 0x000000aa during port configuration of a
  • 72 Answers
SOURCE: 0xc18a0401
Hi!
This problem generally arises when you replace some cartridge which was refilled.
You should need to follow the procedure of changing the entire set of cartridges with a new fresh set and start the 'clear ink failure status' procedure. This will definitely help you.
Thanks
Posted on Apr 28, 2010
  • 1684 Answers
SOURCE: HP photosmart c6180 all in one printer error
The "Ink System Failure" error is caused by air in the ink fed tubes. We have a step by step guide to perform a ink purge on the printer posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Following this procedure should get your printer back running in about 10 minutes.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Aug 03, 2010
OKI c5400 error 0x000000aa port comfig
Hi Fixya
The error you mentioned is related to the Microsoft operating system.
Please find the below article for your reference
http://winwiki.org/port-configuration-error-0x000000aa/
Hope it will solve your issue.
BR
Ganesh
Nov 21, 2014 | OKI C5400 Laser Printer
C6180 constantly resetting itself
http://www.fixya.com/support/t7081394-c8180_continues_reboot
Jan 06, 2012 | HP Photosmart C6180 All-In-One InkJet...
My HP C6180 Printer has an error code Oxc19aoo31. How can I fix it
The error that you are having is a hardware issue, it means your printer is really of no use anymore. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 will not print from windows vista; no error message displayed on computer or printer; print queue says error printing with no explanation wireless installation hp solution center says no hp...
This means that your system does not display any printer name under the printer's list even though you would have installed your wireless printer on your Windows Vista system. This could be caused if you have not updated printer drivers in your system or the printer is incompatible with Windows Vista. Also see if the Windows firewall is blocking the printer from being recognized by your system. get more information for HP Wireless Printer Problems . Hope this helps you.
Jan 12, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error is "oxc19a0035
I have a C6180 that was displaying the 0xc19a0035 error code and the above fixes worked for a while until the printer started power cycling continuously - making it useless. The problem turned out to be failed capacitors on the logic board from a manufactuer called TEAPO - many unfavorable internet references. Look at the capacitos on the logic board, if any look like they have even the slightest bulge in the top, they are failing and should be replaced - see image. On my C6180 I replaced C613, C614, C660 and C662 and the printer is working great!
Aug 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One err oxc18a0201
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
good luck
Aug 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 all in one the error message displayed is ink system has failed it will not print appreciate any help
The Ink System Failure messages on my C6180 were early symptoms that progressed continuous power cycling. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fix stopped my printer from power cycling and also fixed the ink system failures the Printer was having.74b7f9c.jpg
I ordered parts from mouser.com, but DigiKey.com may have better prices. I ordered 3 of these and 1 of these. here is a .
Jun 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 all in one, does not copy or print anymore.
put the old cartridge back, if there have same error message then tell me what error message is, if not that's mean new cartridge is defect.
Dec 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
I have an HP D7360 printer. I receive the error code 0xc05d2281. can you help?
I have a HP Photosmart C6180 All-in-One printer. When I try to print I get error code Oxc05d2281 on the printer scren. I have replaced all the carriages with new one. Please tell me how to fix this problem.
Thanks,
Estella
Jul 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
143 people viewed this question
k24674
