Question about Keurig B60 Coffee Maker
Keurig b60 troubleshoot
No power
    Master:
  • 253 Answers
Call Keurig (866-901-BREW) for help
Posted on Nov 25, 2013
  • 10865 Answers
SOURCE: The brewcover on my Keurig B60 broke. Both screw
Hi. go to keurig.com/parts and order what u need. J.
Posted on Jul 25, 2010
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
heatman101
  • 43501 Answers
SOURCE: keurig model b60...wont power on,
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 03, 2011
How do I fix my Keurig B60 SN#65.0100.3601827 power won't turn on?
It sounds like your power is off. all should be fine when it is restored.
Jan 27, 2015 | Keurig B60 Coffee Maker
What shall I do when my Keurig B60 will not power on when I plug it into an outlet that I know works
This was answered here...
http://www.fixya.com/support/t10647975-keurig_b60_will_not_power_worked_fine
Aug 23, 2014 | Keurig B60 Coffee Maker
KEURIG B60 COFFEE MAKER
If no power, the circuit board is defecetive, return for a replacement.
May 28, 2012 | Keurig B60 Coffee Maker
Keurig B60 will not stay on
Turn off Auto Start. see manual page 17 for indstructions.
Feb 23, 2012 | Keurig B60 Coffee Maker
Keurig b60 no power is there a fix?
Main board defecetive, retun for replacement.
Dec 20, 2011 | Keurig Special Edition B60 Coffee Maker
Keurig model b60...wont power on, dont know where the fuse is
heatman101
Aug 15, 2011 | Keurig B60 Coffee Maker
Where to find K-Cup assembly for Keurig B60 model
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Jul 04, 2011 | Keurig B60 Coffee Maker
My 4 year old Keurig B60 just keeps saying "not
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 19, 2011 | Keurig B60 Coffee Maker
My Keurig B60 will not brew. Power is on but dark display reads Not Ready
I am haivng the same problem all of a sudden, did you find the problem?
Sep 22, 2010 | Keurig B60 Coffee Maker
Jul 25, 2010 | Keurig Special Edition B60 Coffee Maker
Keurig B60 Coffee Maker Logo
161 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
