Question about Compaq Computers & Internet
Compaq presario 5304 boots to desktop,but nothing is on my desktop
  • Compaq Master
  • 27,725 Answers
If you are not a screen after the computer boots up.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
Hope this helps.
Posted on Dec 01, 2012
pagebor
  • 2785 Answers
SOURCE: Compaq Presario SR1710AN Desktop PC frozen on compaq screen at startup
try to boot in safemode.then uninstall the display drivers.plz post your comment
Posted on Apr 21, 2008
pyledriver
  • 7 Answers
SOURCE: Have a compaq 5304, and
your pc is re-booting, the quickest way to solve that prob. is to restore the pc, (hope you have or made the restore disk.) just insert the cd into the drive and re-boot. follow the on screen instructions to restore your pc.email me at arjoon.ken@gmail.com and let me know if you got it going.
Posted on Jan 05, 2009
sodeep
  • 3267 Answers
SOURCE: how to enter bios presario 5304
When you are starting up the PC, keep jabbing the DEL key for the BIOS screen to appear......sodeep
Posted on May 16, 2009
bill406
  • 34 Answers
SOURCE: compaq presario sr1950 nx desktop - won't start
Hopefully you didn't discharge any static into the machine. Try pulling out your memory sticks and turning the machine on. If you hear a repetitive beeping from the computer it's good sign. Turn off the machine. Put the ram back in and locate the jumper near the cr2032 battery. Change the jumper position. Turn on the computer for a second by pressing the power button. If it doesn't turn on, that's fine. Change the jumper back to it's original position. Now try to power up the machine and see if you get any video.
Posted on Nov 07, 2009
joecoolvette
  • 5660 Answers
SOURCE: Compaq Presario SR1620NX Desktop won't turn on
I may state too detailed, and over simplify in my solution.
This is not to insult your intelligence, but an endeavor to explain thoroughly.
To bypass the Power On switch, one uses a jumper wire to jump the Soft Power On wire, to ANY Ground wire.
The Soft Power On wire has Green insulation, and is located in the 24-pin ATX main power cable.
ANY wire that has Black insulation is a Ground wire.
To explain:
This is HP Support, and the Motherboard Specifications page, for the Compaq Presario SR1610NX desktop computer,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127350
I would like you to scroll down the page, until you come to the motherboard illustration.
(Under the - Motherboard layout and photos - heading)
This illustration represents the motherboard from a top view, and with no hardware components installed.
(No Processor, Ram Memory modules, power cables from Power Supply plugged in, and so on)
At the top right of the motherboard is a small rectangle, with an inscription in it.
(The tiny printing reads - SMSC with LPC47M997NR under it)
Immediately below this small rectangle, is the 24-pin ATX main power cable connector.
Two vertical rows of 12 socket holes.
(Next to it is printed - ATX 1)
Now here is a much better view of a 24-pin ATX main power cable, and the corresponding connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The photo to the far left, shows a better view of the 24-pin ATX main power cable connector, on the motherboard.
(Yours may be an opaque whitish plastic. It also will not be located on the outside edge of the motherboard)
The photo in the middle, shows the 24-pin ATX main power cable not plugged in.
The photo all the way to the right, shows the 24-pin ATX main power cable plugged in, and shows the Green Soft Power On wire.
Also shows the Black ground wires.
The 24-pin ATX main power cable is left plugged into the motherboard.
Looking at the middle photo once more, note how the power wires come into the connector.
This is the Back of the connector.
Each wire ends in a metal terminal.
The metal terminal is approximately 1/2 inch in length.
This means the power wire goes down in the connector pretty deep, before it ends in the metal terminal at the Front of the connector.
I use a wire that is approximately the same size, (Gauge), as the power wires, for the jumper wire.
Strip around 1/2 inch of insulation, from each end of the jumper wire, then twist the wire ends.
The jumper wire should be around 3 inches in length, and bent into a U-shape.
Power supply unplugged from power, insert one end of the jumper wire into the socket hole that contains the Green wire.
(Soft Power On wire)
The jumper wire end is stuffed down into the socket hole with the Green wire, right next to the Green wire. You are pushing the bare stripped end past the insulation of the Green wire, with the intent of touching the metal terminal end.
Insure that the stripped bare wire, is touching the metal terminal end, as best as you can.
The stripped end may have to be longer than 1/2 inch.
(An alternate form of jumper wire is a paper clip straightened out, then bent into a U-shape, with wraps of tape in the middle for insulation. I have used this method also. I just don't recommend it for solutions)
Power supply plugged back into power:
With the one end stuffed down into the socket hole for the Green wire, hold the jumper wire by the insulation, and touch the other end down into ANY socket hole that has a Black wire. (Ground)
Warning!
There may be a spark. You may wish to wear a glove on the hand for the jumper wire.
The voltage is 5 Volts (DC)
Two common flashlight batteries are 3 Volts. (DC. Each battery produces 1.5 Volts)
To me it isn't a big deal if there is a little spark. Wanted to advise you beforehand, so that you would be aware, though.
The Power On button that you push is made of plastic. Located inside it is the Power On switch.
With finesse the Power On switch can be removed, and a new one inserted.
(I use a hair dyer on low heat setting, and move the hair dryer back, and forth to gently soften the plastic, so that tabs can be eased to one side, and the Power on switch removed.
The Power On button/switch assembly can also be lowered, {Removed from computer}, into a bowl of very, very warm water, to soften the plastic Power On button. The switch will be removed, and thrown away. The plastic Power On button is then dried, and readied for the new Power on switch)
(Barring the worst case scenario, if a correct Power On switch cannot be obtained, a Power On switch can be used by itself, and would just hang outside of the computer. Not very aesthetically appealing, or professional, but the computer will work again)
I have found that this generic Power On switch, seems to be a correct substitute for most computers,
http://www.directron.com/atxswitch.html
Ebay may have one in Computers and Networking>Computer Components.
Older computers, used a different method to turn the Power Supply on.
(PSU - Power Supply Unit)
The Power On button pushed against a long metal rod, which in turn pushed against a Power On switch, located in the Power Supply.
The Power Supply in your computer always has a constant 5 Volt standby power, when the Power Supply is plugged into power.
When the Power On button is pushed, it pushes against the Power On switch.
Inside the switch is a convex shaped thin disk of metal.
The 'plunger' of the switch, pushes against the middle of the convex metal disk.
The outside edges of the disk are connected to Ground.
When the convex disk flattens, the middle touches a Positive connection.
This contact is Momentary.
The Power On switch is a Momentary Contact Switch.
When you let go of the Power On button, the disk resumes it's convex shape, and the brief connection is broken.
The Power On switch wires connect to pins on the motherboard.
The area the pins are in, is the Front Panel header.
(A connector on a motherboard is referred to as a Header. The plastic piece on the front of a computer is a Front Panel. Sometimes referred to as a Front Bezel)
To remove the Front Panel to your computer, far enough to easily access removing the Power On switch, the Power On switch wires will have to be disconnected from the Front Panel header, on the motherboard.
So will all the wires leading from the Front Panel, to the Front Panel header on the motherboard.
Looking back at the motherboard illustration, the Front Panel header is located on the very bottom right of the motherboard.
JFP1
(Junction Front Panel 1)
You will note that there are two rows of pins.
Four across the top row, five across the bottom row.
BEFORE (Not shouting) you attempt to remove the Front Panel, it would behoove you to make a drawing, and notes as to where those wires go.
If wires come loose, I don't have a way at present to tell you where they go.
It has been a while since I have worked on this series of Compaq Presario's. The wires from the Front Panel may just end in a single connector, that you simply line up with the corresponding pins on the motherboard, and plug the connector in. (On?)
The connector is oriented, by the pin in the Front Panel header that is missing.
Four pins across the top, with one missing.
Five pins across the bottom.
The connector will also have one hole blocked off, to match the pin layout of the Front Panel header.
The other wires from the Front Panel though, may not end in a single connector.
These headers are for the audio connections on the Front Panel, USB ports, and so on.
I'll await your diagnoses to see if a new Power On switch is required, or a new Power Supply.
If it is a new Power Supply that is required, I will give recommendations, and why, if you wish.
Should you have any questions, I will try to reply as speedily as possible.
Posted on May 26, 2010
Testimonial: "Thank you so much! What a great reply! I really appreciate the detail, references to online manuals as well as the suggestion for where to get parts. Wonderful help! THANK YOU!!!"
How to i replace my hard drive on a presario 5304?
If you replace your hard drive with a new one, you will have to reinstall your operating system onto that drive before you will be able to use your computer normally.
All the HOW-TO INSTRUCTIONS for your computer are found at the following link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=useCategory&lc=en&dlc=en&cc=us&dest_page=product&product=93186
First unplug all the cables from the back of your computer and be sure to take note of where they go so you can replace them when you finish.
Take off the side panel from your computer by removing the 2 screws holding it on the back panel of the computer and pulling the side panel firmly backwards. Be sure to lift up up on the big plastic catch if there is one.
Complete details on HARD DRIVE REMOVAL are available at the Compaq Support website at the following link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03429&tmp_task=useCategory&lc=en&dlc=en&cc=us&dest_page=product&product=93186
Remove / replace your hard drive and cables as per the above instructions.
Once you get your new hard drive installed, boot your computer and go to your BIOS screen.
Repeatedly press F1 or F2 or F8 or F10 during startup before anything shows up on monitor.
Change your BOOT ORDER so that your CD / DVD Drive is the FIRST BOOT DEVICE.
Save changes and exit.
Now you can insert the OPERATING SYSTEM INSTALL DISK and reboot your computer to install your Operating System.
Good luck and please comment back and rate if this was helpful.
Feb 04, 2011 | Compaq Presario 5304 (120969-004) PC...
My Compaq Presario would not boot. I happened to lose the recovery disk (I put it away in case something like this would happen, I end up losing it anyway...smh). I have tried everything, from USb booting...
Of course. You can use some live linux distro (Ubuntu in example) or Hiren's Boot CD (one of the best tools, download here: http://rapidshare.com/files/426971514/Hirens.BootCD.11.1.rar )
Oct 24, 2010 | HP Compaq Presario SR2010NX PC Desktop
Does m y copaq presario pc come with a dvd converter
No it does not. You need to download a program from the Internet to convert video files or DVDs.
You did not say what you want to convert the DVD to what video format.
I suggest you do a Google search for DVD video conversion programs.
Oct 15, 2010 | Compaq Presario 5304 (120969-004) PC...
Would like to know how you access the setup menu or BIOS
I believe that you want to press the F2 button as soon as you turn it on, and keep pressing it until the BIOS setup screen comes up, If F2 doesn't work then try F10
Apr 04, 2010 | Compaq Presario 5304 (120969-004) PC...
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Compaq presario sr215onx wont boot up
Go to bootdisk.com and download boot files for your operating system (ex. Windows XP). There are software for floppy disk which is the easier way to get your boot files. If you do not have a floopy you will have to get the CD files, there you have all the instructions how to get the CD. Once you get the files, insert the floopy or the CD and reboot your computer. The filse should be installed automatically, if not do it manually and reboot computer again.
Oct 29, 2009 | HP Compaq Presario SR2150NX PC Desktop
How to enter bios presario 5304
May 16, 2009 | Compaq Computers & Internet
Help
I am glad to help you But what help?
Jan 05, 2009 | Compaq Presario 5304 (120969-004) PC...
Have a compaq 5304, and it will not boot up, it acts like it then it goes compaq page and continues to redo that until I shut it off
Computers & Internet Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
