I have a gateway wireless, had centery link hook it up and i get no power to the monitor
There is power in the computer black pc but nothing going to the screen, keyboard and mouse will not click on screen
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
Hope this helps.
Posted on Dec 01, 2012
SOURCE: Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Posted on Jan 10, 2009
  • 23 Answers
SOURCE: My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Posted on Jan 24, 2009
  • 400 Answers
SOURCE: My gateway gt 5228 has power boots up but I have
First disconnect any external devices like printers etc that you might have plugged in.
If that doesn't work then it's a problem inside the box it can be the power supply ,motherboard ,memory ,CPU and others.
If the PC has warranty then you should take it back.
If you are comfortable in opening your computer then we could try more advanced troubleshooting ,let me know if you want to try it.
Posted on May 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Keyboard/Mouse not working after power supply replacement
Hello there:
ok first remove both the keyboard and mouse
and restart the computer and see if it says anything about no keyboard or mouse present if so this is good now just turn off the computer and install the mouse first and reboot and see if the mouse is able to work and than do the same for the keyboard. please try these first and please let me know how this goes, there is more that we can do if needed ok please dont forget to rate this for me
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 111 Answers
SOURCE: PC to Wireless mouse and keyboard connectivity issue
Hi!
Try checking your power management feature, there should be a tab there that enable/disables wireless capability to during power save mode...
Hope it helps!
Posted on Feb 15, 2010
Testimonial: "Thanks for the advice. Power save was OK. There is a setting called "Allow Hybrid Sleep" This was set to "on". I changed it to off and all seems OK."
I have a zx4351, touch sreen wireless gateway desk top computer , i had cable co. today to hook it and now my screen does not turn on and has no power going to it what is it?
Your desktop tower/cpu tower has to be turned on to give those hardware power. If you can't turn on your computer then that means you have an internal problem with your motherboard etc. If everything else powers up except for the screen/monitor your video is dead. Find someone you know that has an extra monitor and hook it up to your tower, if it works then it's not your video but the monitor instead.
Dec 01, 2012 | Gateway Computers & Internet
When I turn my computer on it boots up just fine & monitor works. At some point, sometimes a few minutes, sometimes a few hours the monitor will go black and I get a no signal message. The system is...
would appear the system is in standby mode you could disable this
in windows 7 or vista go to
start
control panel
power options
choose when to turn display off
Sep 05, 2011 | Gateway Computers & Internet
I have a gateway gt4015e. When I turn the power on the screen does nothing just stays black. This is a windows media center 2005 machine. Please help
Make sure the computer and the monitor both have power going to them and that they are both on.
Make sure that the cable from the computer to the monitor is connected firmly. You have to determine if you are using a video card or on board video (video built into the motherboard). If you have two ports to plug into on the back of the pc make sure you are plugged into the right one. Try to use the monitor on another computer or a different monitor on that computer to see if you can isolate it to one or the other.Could be a bad cable,video card,or monitor. You should try to test the devices to narrow it down.
Jan 10, 2011 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Gateway MD2614u, froze at start up when restart was attempted nothing appeared but a black screen. It will not restart. I have tried the battery/power reset, vacuum any dust and hooked up to another...
Actually this is a hard drive fault most likely, or a faulty had drive. If you don't have a recovery disk you are going to have to start the machine and try to do a recovery to boot repair. You can usually access this with F10 or F12, not really sure on a gateway.
Dec 29, 2010 | Gateway MD2614u Notebook
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
My gateway fpd1975w tft lcd monitor does not work. the power button just flashes blue and nothing comes on. i put an old monitor to my computer and it worked fine, and i hooked my monitor up to an old...
Restart the PC and get into SAFE MODE. Hit and release F8 many times right after turning on PC. If it works, then go into your video setting and either change the settings or remove the video driver. Restart the PC and you'll get 800X600 screen, then reinstall the video drivers. IF it won't go above 800X600, screen internals are bad, LCD toasted. I've seen that happen with LCDs and older monitors.
Jul 05, 2009 | Gateway FPD1975W 19" LCD Monitor
Screen goes black
Try run the computer on main power and check.
If it still does not run then it is issue with the power circuit on computer and make sure this check the power adaptor working properly by connecting to another computer. "It is turning out to be hardware issue. Contact gateway then
Apr 30, 2009 | Gateway MT3705 Notebook
When turn on the gateway screen apear, but the monitor turn off or black and not apear nothing my computer is gateway profile 4 all in one
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Mar 13, 2009 | Gateway Profile 4 All In One (MPN...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
