Printer repair tricolor cartridge doesn't work
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Dec 01, 2012
  • 1738 Answers
SOURCE: The tricolor cartridge status light is blinking.
Ink cartridge will go dry up if you don't use them. I would try cleaning the head and do some maintence on it. It looks to me that you have to buy a new black cartridge. I went through the same thing on mine.
Posted on Nov 15, 2009
Dicedonions
  • 118 Answers
SOURCE: magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Posted on Apr 30, 2010
  • 235 Answers
SOURCE: printer prompting that it is not detecting the
if the ink cartridge is the same ink cartridge since you have pruchased it, it may have run out of ink or the ink cartridge is broken, that is the only two posible reason thats why you always recieve these messages, check can check the ink capacity through the hp utility tools, if the cartridge has run out of ink or it is broken you will need an ink cartridge replacement
Posted on May 11, 2010
micromatikal
  • 2777 Answers
SOURCE: Message on printer window Incorrect cartridge:
I see this type of problem almost every day with these PhotoSmart printers. It is something wrong with the cartridge sensor in the printer. About the only thing you can try that sometimes fixes it is to turn off the printer, then physically unplug it from the wall for at least 2 minutes, then replug it back in.
If it still comes up with the error then unfortunately the printer has effectively died..
Thanks,
Tim
Posted on Oct 28, 2010
  • 1218 Answers
SOURCE: I have a Lexmark P4350
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Dec 16, 2010
Print cartridge installed incorretly
Its not reading the cartridge. There's no way around it, you have to buy a new cartridge. It happens. Especially when you refill cartridges.
Sep 24, 2012 | HP 78 Tricolor Ink Cartridge C6578dn...
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
Will 27 black and 28 tri-colour cartridge work on a D1560 hp deskjet
HP 21 black and HP 22 tricolor cartridges are the cartridges compatible with HP DESKJET D1560.HP 27 and 28 won't work with your printer because they won't get recognized by the machine.It will only give you an error message like incompatible cartridges.
Jul 21, 2011 | HP D1560 Deskjet Printer InkJet
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
My pc says printer in back up mode
that means either the black or tricolor cartridge ran out of ink and it's currently utilizing only one cartridge.let say you ran out of blank ink but tricolor cartridge is still good you can still print or make a copy using only one cartridge but the quality won't be that good
May 31, 2011 | HP DeskJet F4180 Inkjet Color All-In-One...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
It is reading Print cartridge problem(tri-color)
if it is not yet empty try to remove and reconnect the cartridge, if same error, try printing without the tricolor cartridge. if that works, you need a new tricolor
Mar 14, 2011 | HP Officejet 5610 All-In-One InkJet...
I have a HP C4780 printer - does the 300XL cartridge work on this model
The HP Photosmart C4780 All-in-One does not use HP 300XL Cartridge.
Below are the cartridges used by your printer with the no. of page count and their price as per HP
HP 60 Black 200 pages $14.99 HP 60 Black/Tricolor 200 black, 165 color $31.99 HP 60 Tricolor 165 pages $19.99 HP 60XL Black 600 pages $34.99 HP 60XL Tricolor 440 pages $40.99
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 04, 2011 | Office Equipment & Supplies
Magenta in tricolor not flowing
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
I have a hp desk jet 5440 i put i a new tricolor
Make sure that your buying a new Tricolor as the same and Geniune too.
Only solution to this is put it properly inside your printer.
At first sometimes New Cartridge are being initial & calibrate by your printer before it works.
Power Off first your printer and put the cartridge inside. If the problem still exist then put back again your old cartridge and identify what is the problem occur before you put a new cartridge on it.
Sep 23, 2009 | HP OfficeJet J4580 All-In-One Laser...
12 people viewed this question
jasbo
jasbo
