Can't watch movies on computer
Where can i go to install the PCI simole communications controller, RAID controller & Video controller.
Its likely you dont have the neccesary "codecs".
Posted on Jan 12, 2009
Drivers
You need to look for under Toshiba (model number) and OS. It should be the LAN, Sound, and Video.
Intel does make all those devices, but does not necessarily mean that is what you have installed. You could have one or any mix of.
GL
Jan 25, 2013 | Toshiba Computers & Internet
Use of PCI-e x16 slot for non-video card
...........................................!O_O!...........................................................
WHY would you want to do that?
There is a PCI-Express x1 slot on the motherboard.
Black in color, and in-between the black PCI-Express x16 slot, and a white PCI slot.
Use the PCI-E x1 RAID adapter card in the PCI-E x1 slot, and a PCI-Express graphics card in the PCI-E x16 slot. Sheesh!
A PCI-Express slot is not an evolved PCI slot.
Completely different technologies.
PCI uses a shared Parallel bus architecture, while PCI-Express is based on Serial point-to-point.
So your idea of how to 'fix' your problem, is to use a PCI-E x1 card in a PCI-Express x16 slot, and a PCI graphics card in a PCI slot?
Completely backwards.
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
PCI-Express x16 slot uses the same lanes from the Northbridge, as the OnBoard video?
UTTER NONSENSE!
The Northbridge chip handles the Faster capabilities of a computer.
Handles the Processor, Ram Memory, and HIGH-SPEED Graphics.
HIGH-SPEED graphics is the Accelerated Graphics Port (AGP) technology, and the PCI-Express technology.
The Southbridge chip handles the Slower capabilities of a computer.
The PCI bus is one of those slower capabilities handled by the Southbridge chip.
The PCI bus is also a shared bus. This slows data down.
The AGP bus, and PCI-Express bus are Not shared. They also have a direct link to the Northbridge chip.
The PCI Bus has to go through the Southbridge chip, which has to go through the Internal Bus, THEN to the Northbridge chip.
OnBoard video, or Integrated Graphics, uses the PCI bus.
When you inserted the PCI-E x1 RAID card in the PCI-Express x16 slot, and a PCI graphics card in the PCI slot, BIOS just assigned another IRQ for the PCI-Express x16 slot.
(Interrupt Request)
No fancy technology going on there.
Backwards technology going on with a PCI-Express x1 card in a PCI-Express x16 slot, though.
I do not concur, and do not think that is a good solution, Kevin.
Regards,
joecoolvette
Aug 24, 2012 | Gateway Foxconn C51GU01 Motherboard
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
Apr 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
SATA Raid card on PCI unable to detect eSATA Hard Drive
if you install the raid controller drive,it means it will shown the drives..but it not shown? is this what you mean? did you try to see in the computer management? if you dont know, check this out..right click my computer-manage-select disk management and check if your drive is there......this is only what i know about what you mean.
Mar 03, 2009 | Intel Motherboard
Dev Man Errors / drivers
Go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag",(serial number) of the 820 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
The PCI device, simple communications controller is your dial-up modem card.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Jul 01, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
