My pioneer plasma not working
I have pioneer plasma mode no is-504.plasma is dead but red or green indicator are glow.plz help me shotout the problem.
    Master:
  • 879 Answers
Check and replace its main digital board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Dec 01, 2012
SOURCE: pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
Posted on Jul 10, 2008
SOURCE: Red LED lights
power supply shot ... sometimes x board or y board
Posted on Dec 09, 2009
BElectric
  • 1140 Answers
SOURCE: i have a Pioneer PRO
The first thing you need to do is establish whether there is an actual fault with the MR or whether it's a setup/connection issue. You haven't indicated anything you have already tried in order to rectify the problem so I'll have to start at the beginning with the basics:
Isolate the MR
1. Make sure the MR power is off using the "POWER" button on the front of the unit.
2. Disconnect ALL cables from the back of the MR. If you have several connections be sure to make a note of where they all reconnect
3. Unplug the MR from the power outlet and leave disconnected for at least 5 minutes.
The software/firmware in a MR can "crash" in the same way that your PC does. Unplugging it for a few minutes should re-boot the system - basically the same as starting up your PC.
4. Plug the MR into the power outlet again but do not connect any cables.
5. Switch the MR on using the "POWER" button on the front of the unit.
If the MR is still stuck in standby, you have a fault with the MR.
If the MR will power on:
6. Switch the power off again and re-connect the cables for one device at a time then test the MR. Make sure the cable are connected to the correct sockets.
I suggest you connect the TV first then test the MR will power on. Next connect the cable box and test the MR again. If everything is OK, continue to connect any other devices one at a time and test the MR after each connection.
If the MR fails to power on after connecting a specific device, this will give a good indication of where the fault is and what to do next.
If you can re-connect all of the devices and the MR functions correctly, then it was just a simple case of the MR having "crashed" and you can resume normal operation. Should the fault re-occur, simply unplug the box, leave for a few minutes and switch back on. You can avoid disconnecting everything unless the box fails to power up after the "hard reset" - i.e. unplugging it.
This is a very simple test to determine what/where the fault is. Please try all of the above and then post back with the results if you need further assistance.
Regards,
BElectric
Posted on Jan 09, 2011
SOURCE: Hi my Pioneer Plasma #
I have this same problem someone help
Posted on Jan 10, 2011
welcomejee
  • 10594 Answers
SOURCE: Hi. I have a pioneer plasma PDP 506PG and it has
Red light flashing on plasma panel indicates problem with power supply board.
Can you tell me how many times red light is flashing after 1 second interval? It is an error code that has info about defective section in tv.
Thanks.
Posted on Mar 11, 2011
My problem is set is not working but red or green indicator glow,plz help me.
Check this site for more details. It has more than 1400 posts to different brands of electronic entertainment and other equipments. All posts referrers with the repair and fault finding to electronic entertainment equipments. It will be best to view it either in Flipcard or Timeslide option, can be selected by the sidebar tag at the top left of the display screen. Timeslide view will be the best to select. If you are using Google Chrome as browser, Flipcard option will be the best.
Dec 01, 2012 | Pioneer Televison & Video
PDP 504 PG. TV Deed . smps out put Voltage 3.3V & 7.6 V . Pl z Guide Me. Pioneer Plasma Tv PDP 504 PG Thanks , Amen INDIA aminnooani@ymail.ccm
If the power supply has failed then you must check the SMPS unit. The diodes from the secondary sides must be checked including the zener diodes. please check the link below for tips on SMPS service.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Jul 09, 2011 | Pioneer Televison & Video
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer pdp-ro4e keeps going on standby
my plasma pioneer tv gose in to a pioneer media reciver my tv wont come on and they both flash green red green red please help
Mar 08, 2010 | Televison & Video
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Red LED lights
Oct 02, 2009 | Pioneer PureVision PDP-5030HD 50 in....
My 50 inch plasma pioneer elite has a green color. I dont know how my son changed the color scheme on the tv but i cannot turn it back.
Check in your menu under video and see if there are 3 gamma settings for the Red, Blue and Green. Some plasma's have that feature, why, I don't know, they only cause issues with the consumer. They are listed in the service mode but if I were you I wouldn't go there and besides it's a million to one that your son happened to hit that lottery.
Jul 14, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Pioneer elite 504 pu 50 inch plasma black bar horizontal 2" thick in middle of screen
Pioneer plasma tv cut off while in use. Can't turn tv back on.
Aug 31, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
