Question about Canon Sealed Pixma Mx870 All-in-one Inkjet Printer
The black inl isn't printing out only the colour
  • Canon Master
  • 32,281 Answers
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on Dec 01, 2012
Why won't my HP 930c print colour when properties set to colour?
Check in printer properties., mught be you selected as print in gray scale or black & white., there select print in color mode..
Apr 29, 2015 | HP DeskJet 930c InkJet Printer
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
I have recently replaced my black toner in my HP Laserjet CM1015 MFP and now I cant get anything to print? other toner colours are low but haven't given me a low warning so a bit puzzled why I can
Check and make sure the toner is in correctly. Also go to your start menu if you are running windows and look for your print settings print a test page if this isn't working then please message back.
Sep 25, 2012 | HP LaserJet CM1015 All-In-One Printer
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
Hi. I have a Canon MP560. How do I print in only black and white, using only the black ink? Grayscale mixes in coloured ink. The printer will not print at all unless there is colour ink in it. I only print...
Hi
Follow these steps;
- Open the document you want to print - Go to 'file' - 'Print' - click 'properties' in the print window - in the menu select 'Maintenance' - in the 'Maintenance' click 'Ink Cartridge Settings' - select 'Black Only' - click 'OK' - again click 'OK' - now you can print only using the black ink in the printer.
Hope this helps, Please rate if this solution was helpful. thanks!
Aug 27, 2011 | Canon MP560 All-In-One InkJet Printer
I have replaced the black ink cartridge in my Kodak ESP5210, I only need to print in black, now the colour has run out which I don't need (the original cartridge). I have tried taking out the colour...
go to printer & fax right click on the printer then select maintenance look for the cartridges in (default both cartridges will be detected) you must select only black then close it then try to print
Aug 03, 2011 | Office Equipment & Supplies
Canon Pixma 3600 I want black & white printing only for documents Question: How do i turn off the colour cartridges for black & white printing only?
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Jun 06, 2011 | Canon Office Equipment & Supplies
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Print alignment failed / have tried to rectify several times
It seems like it may be a hardware problem, but the best bet for you would be to reinstall the printer drivers. It should fix it,
Jul 27, 2009 | HP Photosmart C7180 All-In-One InkJet...
Canon Sealed Pixma Mx870 All-in-one Inkjet Printer Logo
105 people viewed this question
old marine
old marine
