Question about Tablets & eReaders
How to calibrate my tablet, and my manual says i should have accelerometer coordinate system under my display in setting and i have nothing
Tip
Calibrating The Tablet Pc Pen
Although it may be tempting to open the box and start playing with your <b>Tablet PC</b>, one of the most important things you should do is calibrate your pen. This means spending time with the pen after a few steps to ensure that the tablet PC pen knows the touch screen is used. To do this, click Start, and the parameters of the search field type <b>Tablet PC</b>. On the list of results Tablet PC Settings and from there go to <b>Display </b>&gt; <b>Display Options</b> &gt; <b>Calibrate</b>.Follow the steps to finish the door and remember to save your settings to accept calibration.<br />
on May 07, 2011 | Tablets & eReaders
My zeepad is frozen when I turn it on what do i do?
Please calibrate it by setting/display/calibrate,for capacitive tablet,please do factory data reset or flash tablet.
Aug 13, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How do i calibrate my kocaso m736 tablet touch screen
Go to settings , then display and you will find calibrate.
May 28, 2014 | Kocaso 10.1" Android 4.0 Tablet PC With...
HELP!My Fonepad cant auto rotate!
Go to settings>display and make sure the autorotate is enabled. If it still isn't working then there may be an issue with your device's accelerometer, test it in a game such as temple run.
Mar 31, 2014 | ASUS FonePad
How to adjust contrast
contrast is bundled with color as far as i can tell
you can search "calibrate display color"
or
go to control panel, either by going to windows start screen swipe up to go to apps and go to the catagory windows system(far right),or long tapping the window button on the bottom left of the desktop.
in control panel tap appearance and personalization and then tap display.
on the left is an option "calibrate color" mine has a shield next to it
follow the wizard
Dec 28, 2013 | Dell Venue 8 Pro 64 GB 8" Wi-Fi Black...
Compass
I'm not 100% sure (I'm a new Nexus 7 owner), but I have see some solutions out there. The consensus seems to be that the accelerometer or the magnetometer isn't properly calibrated.
There are apps out there which claim to calibrate your device sensors, but sometimes these apps need to remain open. Compass is often recommended.
The best (and most odd) solution I've heard is to have the app open and wave the nexus 7 around in a figure 8 pattern. Apparently this does some "voodoo magic" and the device seems to calibrate itself.
Lastly, I have also read that android compasses never seem to point to true north in apps like Google Sky, but is more apparent in larger devices.
If that doesn't help I would suggest contacting Google Support to see if there is a better solution or if they can swap it out.
Phone Number: 1-855-83-NEXUS (63987)
Best of Luck!
Dec 19, 2012 | Google Nexus 7
How tk calibrate Coby touchscreen tablet
go under bsettings,then you should see display or calabration go there and see if thats it
Jul 29, 2012 | Coby Kyros 716829701508 Tablet PC
I reformat my archos 101 tablet, now all the files are gone, when I turn it on all I see is Archos A101IT Recovery, can you please help. Thanks.
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
20.3.1. To enter into the Recovery screen - Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual. Go to this web page to see the latest on-line version of this manual.option to another, use the volume buttons. To select an option, press the ON/OFF button. Go to this web page to see the latest on-line version of this manual.
20.3.2. Recovery mode options No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration
Select this, set your device down, start the calibration, and don't touch it. It will re-calibrate the screen. After the calibration is complete, select No to leave the recovery screen.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased.
HOPE IT HELPS AND GOD BLESS!!!
Jun 27, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Tablets & eReaders Logo
41 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
