Changhong cha60gwt I have F9 showing on control panel what does this mean?
2 Suggested Answers
  • 1015 Answers
SOURCE: I have a Chang Hong
I personally have had very little experience with these units so I don't have any tech manuals. If you have your pwners manual there should be a trouble shooting guide and listing of what the error codes mean.
I would contact the place where you purchasced it and see what they will do as it should have at least a year warranty.
I'm sorry tosay that I did call a couple of friends about these units and they both said the same thing that they were poorly made and prone to early failure. Sorry to be of no more help.Good luck. Thank you
Posted on May 25, 2011
I have Electric Ranges the control panel mot working . the light went out and can back on it shows f9
F9 means different things depending on the brand of your range. For example, F9 on a Whirlpool means that there may be a wiring problem while F9 on a Kenmore means trouble with the self-cleaning door latch. Google F9 and your range brand to find out what may be causing it.
Nov 17, 2014 | Kitchen Ranges
L need a code for a changhong tv
  • Changhong 0827 0767 0820 0009 0156 0264 0508 0817 0821 0848 1910
via changhong tv Google Search > Remote Control Programming Codes (second result) > Search in page "Cheng" total time to find: ~30 sec
Oct 05, 2014 | Televison & Video
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
My oven shows a f9-3 code how can i fix this short of calling a repair person
The F9-3 error code means that their is a problem self clean door lock system. Typically their is 2 switches that check the position of the door latch and even if it's open and not in self clean mode the switches are telling the computer the latch is closed. You should if fairly mechanically inclined be albe to find the latch behind the control panel and use the wiring diagram there and check those switches using a meter set to a low ohms setting and check for one switch being open (infinate ohms resistiance) and the other to be closed (zero ohms)
Good luck, i hope this helps
Gene
Jul 31, 2011 | Jenn-Air JJW8530C Expressions Collection...
I have a Chang Hong air conditioner CHA60GWT and only had it for a couple of months and it has a F9 sign flashing on the front of the unit? Is it broker? Will it be under manufacturer warranty still?
May 25, 2011 | Heating & Cooling
What does F9 mean? the oven says Door when i try set the bake temp and after a few min it starts beeping and show F9?
Hello there:
The f9 error code means that you are having door lock mechanism failure or a erc (electronic range control ) problem and needs to be replaced
1st inspect the door latch and ensure that it works properly and is not loose in any way and if this does indeed work properly than you will have to replace the erc ok
Hope this helps
Feel free to rate this solution for me and if needed post me a comment any time for further assistance
Best regards Michael
Sep 22, 2010 | Amana ARGS7650SS Gas Kitchen Range
After self cleaning...F9 showing in panel with continous beeping...what does this mean? the door is still locked.
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(((())))
Aug 07, 2009 | Frigidaire FEF355 Electric Kitchen Range
What is error code f9-00 on sharp mx-3501N
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Thanks,
CF
Jun 25, 2009 | Sharp MX-3501N All-In-One Printer
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
