Question about Nintendo DS Lite Console
Cant connect to internet code:312005
We have a cisco wireless receiver and we cant get the ds to connect to the internet error code :312005
SOURCE: trying to hook up nintendo ds wireless connection,
recieved a error code 051099-1. please advise
Posted on Nov 16, 2009
  • 33 Answers
SOURCE: cannot get a DS to connect to my router.
Our experience has shown that this error message is typically caused by a basic setting in your router, such as transmission rate. Please carefully read the instructions below:
  • Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router Configuration page.
    2. Use the drop-down box on the left to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  • If the router is not listed on our pages, or has no suggested basic rate and transmission rate changes, log into the router, and check likely areas for the basic rate and transmission rate. (e.g., "Wireless Settings," "Advanced Wireless Settings," "Connection Rates") Change the basic rate to "1-2." Change the transmission rate to "2." (Make the change even if only one of those options is available). Test the connection.
  • Another device may be sharing the same I.P. address of the DS. Try manually assigning an IP address to your Nintendo DS.
    1. The first thing you'll need to do is find out the range of IP addresses you should be using. To do this:
      1. Click the "Start" button in the lower left-hand corner of your computer.
      2. Click "Run."
      3. Type "cmd" into the box and press Enter.
      4. Type "IPCONFIG/ALL" and press Enter. The IP address of the PC will be displayed.
      5. The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110).
      6. Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS as you see listed on your computer screen for IPCONFIG/ALL.
    2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
  • Ensure you have entered the correct DNS into the DS's manual settings. You can verify this by using the steps listed directly above (IPCONFIG/ALL).
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Posted on Mar 13, 2010
  • 14 Answers
SOURCE: i am unable to connect my wii consule to the
You can pusch the button also on the router so he can search your wii.
Posted on Jun 16, 2010
ryokea
  • 18 Answers
SOURCE: my ds lite wont connect to our internet i have a
WPA and WPA2 are not supported by the DS Lite, only WEP and unencrypted wifi connections are. There is no known way at the moment to make the DS Lite support WPA of any form so your only three options are to go to WEP encryption, use no encryption (not recommended), or set up an adhoc connection on a computer with that is connected to your router that has internet connection sharing enabled.
Posted on Mar 11, 2011
  • 110 Answers
SOURCE: My Wii was connected to
1. Attempt to relink your Wii to your router from the wireless menu in the Wii.
2. If (1) above does not work, you can reset your router to factory settings then attempt connection again. BEFORE doing this, hook your Wii up to the router with an Ethernet cable to make sure you have a connection and not a problem with your wii.
3. If you decide to do a hard reset, go to the Cisco/Linksys website for complete reset instructions.
http://home.cisco.com/en-us/wireless?referrer=www.linksysbycisco.com
Posted on May 09, 2011
Cannot change transmission rate of Linksys WRT160N
1.With an online-capable game inserted into your Nintendo DS, turn on your system and access the game's main menu.
2.Access the Nintendo Wi-Fi Connection settings.
-These settings are typically found by selecting "Nintendo WFC" from the game's main menu. For detailed directions, consult the manual for the game.
3.At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
entryscreen3-cwz5mha2srvvin44vycqgk0s-3-2.jpg 4.Tap a connection file labeled "None."
emptyconnections4-cwz5mha2srvvin44vycqgk0s-3-5.jpg -If no empty connection files are available, select "Erase Settings" followed by "OK" to create an empty connection file.
5.Tap on "Search for an Access Point."
connection1settings-cwz5mha2srvvin44vycqgk0s-3-9.jpg 6.The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
oIf you receive the error message "No Compatible Access Points Within Range," click here.
7.Tap on the name of your wireless router or access point.
oIf there is a gray padlock next to the name of the wireless access point you wish to connect with, this indicates your router is using a security type incompatible with the Nintendo DS.
If prompted, use the keyboard on the bottom screen to enter the password for your wireless router or access point.
enter_wep1-cwz5mha2srvvin44vycqgk0s-3-14.png 8.Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test.
9.The connection test was successful - Your Nintendo DS is now connected online.
Situation Not Resolved:
If the connection test was not successful, you will receive an error code:
ยทError Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
Apr 21, 2017 | Linksys WRT160N Wireless Router
How do I connect to the internet
With an online-capable game insertedinto your Nintendo DS, turn on your system and access the game's main menu. Access the Nintendo Wi-Fi Connection settings.(These settings are typically found by selecting "Nintendo WFC" fromthe game's main menu. For detailed directions, consult the manual for thegame.) At the Setup screen, tap"Nintendo Wi-Fi Connection Settings." Tap "Connection 1 None." Clickon "Search for an Access Point." TheNintendo DS will search for any wireless networks within range. Once it isfinished searching, it will display the names of all the wireless networks itfinds. Look for your wireless network. What to do next will depend on the"lock" icon you see next to your network on the Nintendo DS. If thelock icon that appears is unlocked and blue, Select "OK," "SaveSettings," and then "Yes." The Nintendo DS will run a connectiontest with your wireless router. The connection test was successful - YourNintendo DS is now connected online and you can enjoy the Nintendo Wi-FiConnection features of the game! The connection test was not successful - Ifthe test was not successful, you will receive an error code. Error Code 51300: This means the security codeor network name entered into the Nintendo DS is not the same one the router isset to. To reach your connection settings, click "back" on the errorcode screen. Make sure to pay extra attention to the security key you find inyour router's settings and enter it exactly as it appears (the key is casesensitive). For all other error codes, go to the Nintendo website or contactcustomer support. If the lock icon is locked and red, Enter your router's WEP keyinto the Nintendo DS Select"OK," "Save Settings," and then "Yes." TheNintendo DS will run a connection test with your wireless router. Theconnection test was successful - Your Nintendo DS is now connected online andyou can enjoy the Nintendo Wi-Fi Connection features of the game! Theconnection test was not successful - If the test was not successful, you willreceive an error code. If the lock icon is locked and grey, and you wouldstill like to connect your Nintendo DS online, you will need to either changeyour router's security to WEP, or disable security entirely. Please note thatany changes you make will affect other devices that connect wirelessly to yourrouter.
Sep 05, 2011 | Nintendo 3ds Handheld Game Console- Cosmo...
Cant connect to the internet..
Hi, What error do you get when connecting to the internet?
Anyways, Probably the Wireless connection your trying to connect to has a Network Security enabled on it.
Gaming consoles cant' access that type of Encryption, reason I do not know why but to be able to get wireless connection using your Nintendo DS you will need to disable the Wireless Network Security of your Wireless Router to be able to get Wireless Access using your Nintendo DS.
I also had issues with mine before and found out that disabling the Network Security will let me get Internet Access on my portable console.
Just Disable the Network Security this will allow you to get Internet Access on your Nintendo, for the Security of your Wireless you can get the MAC Address of each wireless device you have and input those MAC Addresses into the Router Settings to get Security and not allow other poeplt to gain access on your Wireless Internet.
I hope this Helps.
Have a nice day,
mvincentc
Jul 27, 2011 | Nintendo DS Lite Console
I use a Cisco Wireless-N Router E1000 to connect wirteless laptop. The Cisco is connected to the main router to internet. IP internet router is 192.168.1.254 The Cisco router is 192.168.1.1 The laptop...
I'm confident that having both routers distributing the same subnet is causing a conflict.
You should change the Cisco router to 192.168.2.1. and let it deliver IP addresses by DHCP.
That should do the trick.
May 13, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
Just purchased a Cisco Linksys E1000 Wireless-N Router. I am unable on my wireless laptop to connect to the internet. The Error I am getting from my computer is: The settings saved on this computer for the...
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
Dec 25, 2010 | Linksys E1000 IEEE 80211bgn Wireless...
Trying to connect to internet error code 051112 - 1
Error Code: 051112 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Connecting from a wireless home network:
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off.
If the above information does not work, and you are using the Nintendo Wi-Fi USB Connector, click here for additional assistance.
If the above information does not work, and you are connecting at home with a wireless router, there could be settings on your router that need to be adjusted. Please click here for more information.
Connecting from a Hotspot
  • Ensure the Hotspot location does not require an internet browser to setup an account, accept a use agreement, or enter a password before accessing their Wi-Fi serice. If the location requires any of these items, you will not be able to connect to the Nintendo WFC.
  • Make sure that the DS is within 30 feet of the wireless access point and facing in its general direction. Signal strength can vary, depending on where the access point's signal is coming from. (Please do not sit or stand in places that will interfere with the location's customers or staff.)
  • Orientate the Nintendo DS so that your body or other objects (such as walls, plants, furniture, and other people) are not blocking the signal. Also, make sure there is no interference from wireless phones (cell phones are okay).
  • If the connection continues to fail, this Hotspot may have their router set up in a manner that is not compatible with the Nintendo WFC.
Aug 16, 2010 | Nintendo DSi Black Console
Ive tried to get the internet working but it keeps saying error code 051110-1 what does that mean?
Error Code: 051110 The Nintendo DS is unable to connect to an Access Point. What to do will depend on where you are connecting from:
Aug 08, 2010 | Nintendo DSi Black Console
Error code:051110-1
Jun 26, 2010 | Nintendo DSi Black Console
Connect dsi to the internet
Mar 07, 2010 | Nintendo DSi Black Console
Nintendo DS Lite Console Logo
273 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
