I can not get the drive to work - Computers & Internet
  • 27,725 Answers
What is happening with your hard drive ?
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 01, 2012
I have a USB floppy disk drive that is not working in my pc
Windows 10 does not have floppy disk drive support for internally installed floppy drives. USB drives should work. I have a TEAC external that works just fine with WIN 10.
Floppy Drive support in Windows 10
Nov 18, 2016 | Computers & Internet
My 4wheel drive doesnt work? What can I do or look at to fix?
4 wheel drive does not work - CarGurus
www.cargurus.com > Questions > Chevrolet > Suburban
CarGurusDec 17, 2009 - 4 wheel drive does not work - When I put the Sub in 4 wheel drive, low of high ... I want to "add" 4 wheel drive to my 95 1500 suburban w/ a 350.
My 4 wheel drive stopped working - CarGurus
www.cargurus.com > Questions > GMC > Sierra 2500
CarGurusJul 15, 2014 - My 4 wheel drive stopped working - After struggling with the 4 wheel drive ... sometimes in low sometimes in high, now it doesn't engage at all.
4WD not engaging all the time. - CarGurus
Dec 05, 2015 | Cars & Trucks
I need to get working non dell harddrives
Hard drives are hard drives. They will work in any computer..
Mar 13, 2014 | Dell POWEREDGE 1950 Server
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
My pen drive works on different computers but doesnt work on mine. I have pen drives that work on my computer except this one. It's a Sony 4 GB pen drive and worked on my PC till a couple of days back. Now...
Check your computer for recently installed updates and use the system restore to try to restore to a point before the drive stoped working. Also, carry out a full virus scan.
Feb 20, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Dvd drive won't run but cd drive works fine
Check plug connections / swap cables and retry.
If it now works then cable is faulty.
If still no go then replace DVD drive.
Jan 13, 2010 | Sony Computers & Internet
My drive smells like it is burnt out
I would say the drive overheated & fried since a different drive works it is not the computer. Sorry. Hope this helps.
Dec 31, 2008 | Glyph NetDrive (ndfw1b-80) 80 GB Hard...
Western Digital My Book Pro - Replace Disks
Same problem. This from WD Answer ID 1664:
Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss.
So Hitachi drives will not work at all. After talking to tech support, it seems you have to have them send you a replacement disk in order for it to work.
I'm looking for a way around this since I want to upgrade my dual 500 G drives with dual 1 TB drives also. Maybe they throw something onto the boot sector that tells the MyBook controller what to do, who knows? The search goes on.
db
Oct 24, 2008 | Western Digital My Book Essential Edition...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Drive cd dirve not working
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click Troubleshooter to start the troubleshooter for this device.
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
