Question about Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice
My friend formated the polaroid pmp 120-4 4gb so now when it is plugged in the pc or turned on it says empty disk. pc doesnt even find. how do i
Polaroid mp4 pmp 120-4
are you plugging it in to your computer or a usb hub? if one of those is what you are using and it doesn't work, then try the other. if neither of those work, I would suggest using the Polaroid support line: 1-877-768-8483. Mon-Thurs 9AM-5PM and Fri 9AM-3PM. (Eastern Standard Time)
There is also an email:
polaroidsupport@southerntelecom.com
I hope you find a solution
Jun 30, 2013 | Polaroid PMP120-4 4GB USB 2.0 MP3 Digital...
Polaroid PMP 418
"works like new" may have been somewhat of an exaggeration.
Nov 22, 2017 | Audio Players & Recorders
I need software fo a 4GB Polaroid PMP 287c-4 MP3 PLAYER
No drivers needed for most computer operating systems. To view, add and remove files from the PMP283C-4, just plug it in to a PC using the USB data cable and look under My Computer for "MP3" or "Removable Disk".
The only software you might need is to convert videos to a format that the PMP283C-4 can use. If you don't still have the original CD, then download "Any Video Convertor free" from anvsoft (link below) and use it to convert your videos to MP4 (xvid) 320x240. ANY VIDEO CONVERTER free downloadDVD Converter YouTube Google Video Video...
Apr 06, 2013 | Polaroid PMP283C-4 Music & Video MP3...
Empy Disk message
It could be the format of the player not compatible with the source of your music. Check the settings of your computer and MP3 player. For example are they both Fat 32 or something on those lines?
Sep 24, 2017 | Polaroid Audio Players & Recorders
Empty disk !
verify if your music format is supported by your player
Nov 24, 2012 | Polaroid Mp3 Music & Video Player 180-4
My polaroid pmp 350-4 is basically a paperweight. it wont turn on. My computer does not recognize it. What can I do? I only used it for 2 months.
I just bought a used one online and at first thought that it was broken. I looked at the manual and at first was frustrated. Then I first just plugged the unit in my computer and it lit up and charged...that gave me hope!
Nov 09, 2011 | iRiver PMP-120 Digital Media Player
I bought the polaroid 4GB touch pmp 280-4 for my daughter and it worked for the first week after she got it. Now it wont turn on. can someone tell me how to address this issue? thanks, Shannon
tengo un polaroid de 4GB pmp 280-4 el problema es que e vajado videos pero cuando lo quiero ver no puedo por que dice que no es el formato este es el problema que tengo con eso si puedo vajar musica y escucharlo pero no puedo ver los videos que bajo por que dice q no es el formato ps
Feb 03, 2011 | Polaroid Audio Players & Recorders
How to repair my jxd661 mp4player given detail in below
i think it ur mp4 hardware problem. i have also faced same problem some days ago. so u go to tecnician
Jul 25, 2009 | Audio Players & Recorders
Polaroid Freescape 4360 PMP...database problems?!
Doesnt use CE. Power up and hold the middle touch button. Select option to rebuild the database.
Sep 25, 2008 | Audio Players & Recorders
Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice Logo
198 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Owen Barnes
Mars Nspace
Mars Nspace
Level 1 Expert
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
