Question about Sewing Machines
I have a New Home sewing machine model 900 XL II. I just replaced a lost foot pedal n Im trying to use it but it moves backwards. I cant find the manual. And the bobbin thread seems to want to tangle up under it. In the casing
  • sierraanjel1
    sierraanjel1 Dec 01, 2012
    it is stuck in reverse. how can I clean it. it was in storage for a long time.
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
Free service manual for janome/new home 900 XL II sewing machine
Service manuals are difficult to find because they were intended for technicians and not the owner. However, if you search the internet (Make Model Service Manual), you may find what you are looking for. May not be free, but you can decide then what it is worth to you.
Oct 07, 2016 | Janome Sewing Machines
Do you have a foot pedal for Singer 2210?
Your foot pedal works on several models of high-end machines, including a Bernina. Unfortunately, while you can easily purchase a replacement at several sites, it's pricey. However, I took a look on eBay, and there's one for sale there for $50, which is much better than $149, which is the list price. Here's the link
http://www.ebay.com/itm/Singer-2210-Quantum-DSX-DSX-II-LE-XL-1000-XL-5000-XL-6000-Foot-controller-/261741269436?pt=LH_DefaultDomain_0&hash=item3cf0fed1bc
Jan 21, 2015 | Singer Sewing Machines
Are Bernina Nova 900 foot pedals still available?
My "new" Bernina 900 (I just bought it) has another foot pedal than Bernina that is perfect : a YDK !
Mar 12, 2010 | Sewing Machines
My brother xl5700 is grinding when I press the foot lightly when I press firmer it goes to fast I had the foot changed but still not right
The foot pedal was replace?
If it is not right take the machine and foot pedal back and have another installed.
Test before taking home.
Mar 07, 2010 | Brother XL-5700 Mechanical Sewing Machine
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
Brother XL 6050 internal jamming
maybe that is so old .You can change with new model.New Power Gear Shank 1/8 Rolled Foot Replacement for Sew Machine.
Amazon com NewPowerGear Shank 1 8 Rolled Foot Replacement for Sew Machine...
Feb 13, 2018 | Brother Sewing Machines
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
