Question about Panasonic DMRES15 DVD Recorder
Remote control does not work, Model DMR-ES15
Hello.
I just press any button of the remote control and the DVD displays a word "SET 1" this is al I get and I can not use any key of the remote control, I am not sure how to fix it.
I really appreciate your help...
Regards...
  • 1 more comment
  • jhm1 Jan 31, 2009
    Pretty much the same as above except that mine keeps saying press enter to fix a problem with a DVD recording disk.
  • jhm1 Jan 31, 2009
    Oh and just a s add on the display keeps saying U88 its trying to save a dvd disk and keeps shuting the machine down
  • swisschalets Feb 17, 2009
    I was in set up, in the remote code section, i got stuck when i panned to the third set option. Now when I hit any key on my remote, the display reads"set 3" Please HELP. :)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Press ENTER and the number shown on the unit (SET 1, 2 or 3) together on the remote control for at least two seconds to restore control.
Posted on Apr 24, 2009
  • victoriamary Dec 06, 2010
    Thank you - I've been trying to make my DVD work for a while and I tried what you mentionned and it worked - again thank you *-*
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Onkyo DR90 DVD Remote Will Not Operate Components
Your Onkyo DR90 DVD Receiver remote control does not have universal remote functions, and cannot be (easily) programmed to control a Panasonic DMR ES15. Your DR90 remote does have a limited learning function, but it is designed to learn the codes from your TV's remote to control the TV. Only the following buttons are programmable by the TV Learning function:
I hope that helps.
______________________________________________
Onkyo DR90 DVD Receiver User Manual Download.
Apr 14, 2010 | Onkyo DR90
Remote won't work
According to page 15 of the manual, you should "Press and hold [ENTER] and the indicated number button at the same time for more than 2 seconds" This will work for SET 1, SET 2, etc. If you have lost the manual for the DVR/Remote you can download a copy at http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.pdf
Jan 02, 2010 | Panasonic DMRES15 DVD Recorder
Panasonic DMR ES15 remote stopped working with dvd/recorder...
Try holding enter button and 1 together on the r/c for at least 3 secs
Sep 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
I have a panasonic DMR-ES46V vcr/dvd HDMI i lost the instruction manuel and need to reset the remote to work agin i dont have the codes to do so all the display says is set 1 and the remote dosnt work
1) Hold The Enter Button Down On The Remote
2) Press And Hold The Numeric Button "1" For About 3-4 Seconds
3) Your Remote Is Now Reset To The Remote Control Code #1 (Default Setting)
Apr 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic DMR ES15
Got me too... If the buttons on the main unit work normally, then possibly main unit and remote control are using different codes. Main unit shows SET 1; change remote control code to match it: Press and hold [ENTER] and code number [1] keys for more than two seconds. Fix listed in Operating Instructions troubleshooting guide, Operation section (pg 42). MULTI.PDF">http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.PDF
Apr 30, 2008 | Panasonic DMR-ES10 DVD Recorder
Set 1
Had this same problem and found the solution elsewhere on the net. Hold down the "1" button and the "Enter" button for aprox 10 seconds while pointing at the player. This "resets" the remote. I was skeptical when I first read this solution but it worked for me!
Jan 14, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMRES15 DVD Recorder Logo
1,289 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
