Question about Kenmore 63942 Dryer
Dryer will not turn on
Kenmore dryer problem. Does not turn on it has power belt is not broken there is no noise when i hit power button what is
  • Kenmore Master
  • 3,463 Answers
Hi there. Thanks for your request re dryer prob.
I guess you live in the states, as we do not have Kenmore dryers here in the u/k.
However here are some suggestions.
In am assuming that you have determined the dryer has power to it, if that is o/k , then it could be the door switch not activating, the timer not working the actual switch that you press to start could be faulty, the list is quite long.
I suggest you try the following.
In your browser bar type in -----youtube
Then in the search box type in ------repairing kenmore dryer
This should present you with a list of very comprehensive videos on how to repair and service Kenmore dryers.
I really would deem it a big favour if you would let me know if this link works, as I have not tried it before.
Hope this helps you with your prob, and once again thanks for asking.
Plz rate my comments.
Thanks.
Posted on Jan 13, 2009
My Kenmore d433 dryer won't start
you good have a broken belt , are motor over heating if you know how to take off front panel to check an see is belt are motor make sure u unpulg are trun power off are just call appliance pair service ok hope this will help out
Jun 05, 2017 | Kenmore Dryers
All power is good, heats up but drum won't turn. Hear humming noise after pushing start button. Relaced motor,thermal fuse and thermistor. Still nothing. Checked door switch. Any other suggestions?
Betty,
When you replaced the motor, did you also replace the belt? If you had not said that you already replaced the motor, I would have suggested that the belt was broken.
Jun 09, 2015 | Kenmore Dryers
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
With the power on, once I hit the "start" button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 97566 Electric Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Mar 15, 2009 | Kenmore 84052 Dryer
Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
106 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
