I have Hisense 22inch HSL5529HDI it has sound but no picture, it shows Hisense id display banner but no menu or pictureetc.
I have Hisense 22inch HSL5529HDI it has sound of channels but no picture, it shows Hisense id display banner on startup but no menu or picture follows. I have tried holding menu button when starting the unit and whatever I could think of. The remote control seems to work changing the channells but I cant seem to enter any menu for adjustment or whatever. The 3 yr warranty has expired last may so I aseem at a loss...it seems to have a usb terminal but I beleive that is only for service. If you could help it would be good
    Master:
  • 879 Answers
Its main digital board should be troubleshooted. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Dec 01, 2012
legna
  • 53 Answers
SOURCE: NO TV PICTURE
The best way is to contact your service provider and ask them to trouble shoot guide you, there should be a way to reset or diagnose the receiver or if you prefer go back to the place you bought it and ask for a replacement, You should still have the manufacturer's warranty, check that as well.
Posted on Dec 14, 2007
Ajkill
  • 2035 Answers
SOURCE: Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Posted on Aug 01, 2008
  • 223 Answers
SOURCE: INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Posted on Oct 01, 2008
  • 1121 Answers
SOURCE: menu keeps flashing remote control wont work, cant
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Posted on Nov 29, 2009
Highdefjeff
  • 124 Answers
SOURCE: 46 inch sony picture too wide cant adjust with remote
If the Dish remote won't change the picture size when you use the "Format" button (either bottom left on remote or the "page up", "page down" buttons), then you will need to try the Sony remote. If the Sony remote doesn't have a "picture size" or "format" button, then enter the Sony User Menu and look in "Set up" for "Picture Size" "Format" or the like.
Hope this helps!
Posted on Jun 12, 2010
Testimonial: " extreme thank yous. I have put up with this problem since new, about a year, with all kinds of suggestions. None solved the main problem. Wife will be eastatic."
Hisense tv picture is upside down, it was working fine
If the picture on the TV is upside down, press the Menu button, then check the following:
? If the Menu is displayed correctly the problem would be a setting within the external source or a signal issue. Please contact the manufacturer of the external device for further assistance.
? If the Menu is also displayed upside down, then the TV will require service..
Nov 08, 2016 | Hisense Televison & Video
Black screen
Possible causes
  • Your TV is not receiving or displaying the signal from your DIRECTV® Receiver.
  • Your receiver has correct guide information, but is not processing video correctly.
  • You are viewing a channel where an upcoming sporting or special event is scheduled or has recently ended.
Solutions
  • Turn TV off and on.
  • Make sure light on front panel of receiver is lit.
  • Press the "TV/DSS" button on the remote control or front panel of the receiver (not all receivers have this option).
  • Reset the receiver by unplugging the power cord for 15 seconds.
  • Check all cable connections between the dish, receiver and TV.
If the picture is black, but the program title and description display in a banner the top of the screen:
  • If the problem is only occurring on a few channels, check the detailed description of the program through the on–screen guide on those channels. Often, we display a blank screen with a banner before and after a high–profile event to alert customers about the event.
  • Reset the receiver by turning off and unplugging the power cord for 15 seconds.
  • Run a signal meter test to check your signal strength (press "menu" and look under "setup" or "installation").
If your signal strength is below 70 (or below 60 on HD receivers) in clear weather on transponders 1 and 2, see our troubleshooting steps for "Searching for satellite signal. Please stand by." You may see zero strength on transponders 4, 12, 18, 20, 26 and 28. This is normal in many areas. Your system manual shows how to run cables and point your dish.
Oct 24, 2007 | Toshiba 30HF66 30" TV
Tip
How to display your banners in handy cafe- internet cafe manager
its very easy to display ads and banners in internet cafe.You can make extra revenue from it. Here is the tips to add banners in handy cafe server and it will show when a user log in to the client computers. <br /> <b>Login</b> to <b>handy cafe server</b> using <b>user name and password</b> <br /> <br /> <br /> Click on <b>Options</b> Tab <br /> <br /> <img src="shabype.JPG" /><br /> <br /> <br /> <br /> Select <b>Banners</b> from the list and Click on <b>New</b> <br /> <br /> <br /> <img src="shabype_0.JPG" /><br /> <br /> <br /> <br /> <b>Add/Edit Banner</b> will pop up.Click on <b>Add button</b> <br /> <br /> <br /> <img src="shabype_1.JPG" /><br /> <br /> <br /> <br /> <b>Browse</b> for the banner file ( must be a video file) <br /> <br /> <br /> <img src="shabype_2.JPG" /><br /> <br /> <br /> <br /> Click on <b>Open</b> <br /> <br /> <br /> <img src="shabype_3.JPG" /><br /> <br /> <br /> You can see the attachments. Click on <b>OK</b> and then Click on <b>OK</b> again. <br /> Now you can login to any client system and see the ad displaying .You can set <b>time period </b>as your wish.
on Dec 28, 2010 | Computers & Internet
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
How can I get the picture back? Do I let is dry?
Hi, what a shame. You have probably tried everything, but you have not been to the menu on the remote, try that.
Find picture and attempt to adjust the brightness. If that does not work talk to a to- shop person.
all the best,
kolbrun
Feb 01, 2015 | Hisense Televison & Video
How do you change to the banner on the lg tu720
To change banner ,,You hit menu button and go down to settings & tools,,thenscroll down to display settings,,once you push that you will see banner ,,open that up and theres your banner options ,,goodluck
Oct 21, 2010 | LG Shine (CU720) Cell Phone
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
147 people viewed this question
Top Televison & Video Experts
Electro Med Services...
